Switch Turned on for no reason
OK so I have had two switch turn on for no reason that I can find.
The first one was my pool pump switch (deta outdoor power point) tuya, the second one was an s26 sonoff that turn on my heater and it was lucky that I had a 10 minute timer that turned it off. I have no idea why these are turning on
What kind of switches are they?
Precisely at 8:00.00
Not likely a random false trigger.
What else you have at that time in your log?
Absoluty nothing at 8:00PM
I also had a random outdoor switch turn on that runs the pool pump.
I do have an automation for th epool pump but that was disabled at the time.
Now with th epool pump what is suppost to happen is any time the pool pump turns on it should also turn on the UV Filter but that was not happing only the pool pump was turning on…If i manually turned on the pump the uv would also turn on …so i have no idea hoe that was happing
Follow the situation. Interferences exist. Something else at 8.00.00 starting, even if not logged? For sure it’s not random…
OK so 100% my fault as I found the random not so random switches turning on I also found my wife was getting notifaction for things that I had canceled .
It turned out to be a backup of HA running on my synology nas virtual machine that had been set to auto start on the reboot of the nas and of course the power had gone out and when i rebbot the nas that VM started and is a diferent IP that my HA that runs in Docker… My Bad but found that problem
