Hi all,
I have a ventilation system in my home that is working with 3 switches. The way it operates is with press and release switches. I have 3 buttons at home and each button is associated with a speed. If I press and release the first one, then it goes into speed one, etc.
You can see on the image, that the buttons are discovered and if I click on vent_niveau3 then again on vent_niveau3 then it will put it on then off then my system works.
I cannot let it turned on, I need to do on then off immediately and then it works.
How can I create a button that will simulate each time an on then off of this switch in a short interval.
After that, how could I have a select box with the speed and I chose 1 or 2 or 3 and then it will do the on and off rapidly on the corresponding speed button?
Thanks if you can help,
John.
