Switch with 8 buttons to run 8 different scripts
The folliwing code is starting the script if I push button 1 (property_key: '001').
Is it possible to run different scripts if i push button 2 (property_key: '002') in the same automation insted of having eight different automations.
alias: SWI - AUT - NAMRON 8 - TEST MULTI
description: Namron switch
  - platform: event
    event_type: zwave_js_value_notification
    event_data:
      node_id: 30
      device_id: 2573389a45104a1eab8a9d3d80869295
      property_key: '001'
      value: KeyPressed
condition: []
  - service: script.test2_45_sec_on
mode: single
Yes, using trigger ids and then the choose action. Below is an example code of a 4 button Ikea remote I use to control various things:
  - device_id: c587c817945bdbb7537be12fb598319f
    domain: zha
    platform: device
    type: remote_button_short_press
    subtype: turn_on
    domain: zha
    platform: device
    subtype: turn_off
    domain: zha
    platform: device
    subtype: left
    domain: zha
    platform: device
    subtype: right
    domain: zha
    platform: device
    type: remote_button_long_press
    subtype: dim_up
    domain: zha
    platform: device
    subtype: dim_down
    domain: zha
    platform: device
    subtype: left
    domain: zha
    platform: device
    subtype: right
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: script.play_spotify_on_chromecast
      - conditions:
        sequence:
          - service: script.stubru
      - conditions:
        sequence:
          - scene: scene.audio_xbox
          - scene: scene.tv_input3
      - conditions:
        sequence:
          - scene: scene.audio_chromecast
      - conditions:
        sequence:
          - scene: scene.vol_2
      - conditions:
        sequence:
          - scene: scene.vol
      - conditions:
        sequence:
          - choose:
              - conditions:
                  - condition: device
                    device_id: e80332406a3d6c6fa527e148fc1f7f93
                    domain: media_player
                    entity_id: media_player.chromecast
                    type: is_playing
                sequence:
                  - service: media_player.media_pause
              - conditions:
                  - condition: device
                    device_id: 1af7dc36ce3e6e47230d29ad3420d165
                    entity_id: media_player.xboxone
                    type: is_playing
                sequence:
            default: []
      - conditions:
        sequence:
          - choose:
              - conditions:
                  - condition: device
                    type: is_paused
                sequence:
                  - service: media_player.media_play
              - conditions:
                  - condition: device
                    type: is_paused
                sequence:
                  - service: media_player.media_play_pause
            default: []
    default: []
mode: single
i tried this but get it wrong
alias: SWI - AUT - NAMRON 4 - TEST MULTI
description: Namron bryter
  - platform: event
    event_data:
      node_id: 30
      domain: switch
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 30
      domain: switch
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 30
      domain: switch
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 30
      domain: switch
      value: KeyPressed
condition: []
  - choose:
      - conditions:
            property_key: '001'
        sequence:
          - service: script.scr_x001
      - conditions:
            property_key: '002'
        sequence:
          - service: script.scr_x002
      - conditions:
            property_key: '003'
        sequence:
          - service: script.scr_x003
      - conditions:
            property_key: '004'
        sequence:
          - service: script.scr_x004
mode: single
The answer is in @tjafbe post…make sure each trigger is assigned an ID:
    domain: zha
    platform: device
    subtype: right
In this case its spotify
Then in your action choose, each condition references the the ID assigned to the trigger:
  - choose:
      - conditions:
        sequence:
The above action will fire now when the trigger associated to ID spotify happens. That should tie everything up for you
Thx, now it works.
