Switch with curtain/cover visualisation?
Hi guys
I have searched quite a lot but haven’t found an answer yet to my problem so I’m hoping I can get some help here.
I have switches that control curtains through a simple KNX actuator, this is one of them:
switch:
  - platform: knx
    address: '0/0/1'
    state_address: '0/2/0'
This works fine and the state address represent the actual position.
Now I’m looking for a way to change the switch button with a curtain/cover and of course a way to see/know the current position.
Can any of you put a newbie in the right direction please?
Thanks a lot in advance!
Nick
Take a look at the Template Cover.
Hi VDRainer!
Thanks for that tip.
I did see that part of the documentation but I cannot see how to bend a switch to this… :blush:
Can you (or someone else) elaborate a little please?
TIA
Nick
Then you should also read it.
There’s an example that uses switches.
Got it - sort of - working now with 2 minor things:
  • the visualization is a vertical curtain while the actual situation are horizontal ones
  • the state doesn’t follow when the control is done from KNX, which it does with a button by using that state_address
configuration.yaml:
switch:
  - platform: knx
    address: '0/0/1'
cover:
    covers:
      curtain_a1:
        device_class: curtain
        friendly_name: "Curtain back left"
        open_cover:
          service: switch.turn_on
            entity_id: switch.curtain_a1
        close_cover:
          service: switch.turn_off
Regarding the visualization: I have searched for the available icons but haven’t found anything for horizontal curtains. (also changed the device class)
Do they exist and if yes, where can I find them.
If not, I guess I can create something myself but have no idea howto approach this.
For the state, do I use that value_template as in the example?
Nick
I think the curtain works like a normal shutter.
You should use the cover configuration: https://www.home-assistant.io/integrations/cover.knx/
To know the state you will need the “position_state_address”
Hi Joca
Thanks for the tip: I did see that doc but it seems that it doesn’t add anything to the solution.
Since I’m fairly new to home automation in general and HA, this is what I puzzled together.
In this case there is a normal actuator that controls relays, that were already in place, and it’s to much to change all this.
Therefor I have only the control to fully open/close and the state; that’s why I used a switch.
Nick
