Switch with nordpool
Hi everyone,
I’d like to set up my switch to turn on when electricity prices are low. I know this might be a basic question, but please bear with me. I’ll be honest—I’m not a big fan of YAML or templates, but it seems like I might not have a choice.
I have a Shelly switch connected to Home Assistant (HA) and the Nordpool integration. I’m using a YAML template to better format the entity Nordpool2, which I then display via Apex Charts to show four different price tiers. The logic I’m using is based on quartiles: I want the switch to be active during the Q1 and Q2 quartiles (lower prices) and avoid Q3 and Q4 (higher prices).
Is there a way to achieve this without using a template in YAML? -In a later stage I want to add some smart logic with timers, like if it have been sunny the last 5 minuts and the production is above X kW start, as well have a timer if it have been cloudy more than 5 min turn off.
As far as I know, there isn’t currently a stand-alone integration that can do what you are asking, so you will need to use Templating in order to perform the necessary calculations.
You may want to check out the Cheapest Energy Hours Macro. It can be installed using HACS and works with the Nordpool integration’s sensor as default. Once installed, the macro can be used in the Template Helpers. So, depending on what you are trying to do, you may not need to do any YAML configuration.
I use simple automation with nordpool entity, works well
Is it something like that you are after?
This is simple and nice, but, it appeat that after recent update, that entity is not available anymore. Have you noticed that?
Uhm, that one is for Sweden region 3, I still have it at v0.14
Have you created for your region?
I lost mine at 0.15 too, reverted back to 0.14.
Sure, NO1 Oslo region, it worked until yesterday update 0.15
Have you tried to update?
Nope, I don’t see the update yet actually
So, it’s a bug/change in 0.15 then, now I won’t update
It’s a cornerstone addon, coz winter is coming​:eyes::partying_face:
Thanks to both @Didgeridrew and @Patrick-Ohlson. I don’t really like how I solved part of my issue, but here we go:
I added the following code to my template.yaml and created an automation:
- sensor:
    #### NordPool Dynamic Quantiles
      - name: "Q1 Nordpool quantile"
      unique_id: fffe9476-2349-4d81-a5ff-e5f31d22f89a
      icon: mdi:cash
      unit_of_measurement: "öre/kWh"
      state: "{{
        state_attr('sensor.nordpool_energy_prices','q1')
    - name: "Q2 Nordpool quantile"
      unique_id: fffe9476-2349-4d81-a5ff-e5f31d22f89b
      icon: mdi:cash
      state: "{{
        state_attr('sensor.nordpool_energy_prices','q2')
    - name: "Q3 Nordpool quantile"
      unique_id: fffe9476-2349-4d81-a5ff-e5f31d22f89c
      icon: mdi:cash
      state: "{{
        state_attr('sensor.nordpool_energy_prices','q3')
    - name: "Q4 Nordpool quantile"
      unique_id: fffe9476-2349-4d81-a5ff-e5f31d22f89d
      icon: mdi:cash
      state: "{{
        state_attr('sensor.nordpool_energy_prices','q4')
Woops, that is always true, need to add comparison for the current hour
If you update (I have NO1 Oslo region on 0.14) you need to delete the integration and install it again, then select the NO1 region (not Oslo). Then you will get a sensor.
I have tried to revert, picked some full backup from few days before, but my ApexChart does not work anymore, very strange. And yes, I have changed it to NO1, but no luck, its same.
So:
Update to 0.15,
Remove integration
Install integration
I will give it a try, thanks.
The sensor name changes. Either update your charts or rename the sensor to the old name.
Done that, all fine now. Thanks for help!
In the automation, I used the following code. I just hope it won’t trigger too much during sunny hours.
alias: Manage Floor Heating Based on Energy Prices and Solar Production
description: >
  Turn on floor heating when prices are low (Q1), turn off during
  overproduction, and turn off if no overproduction and not in Q1.
triggers:
  - trigger: numeric_state
    entity_id:
      - sensor.ams_ec5d_po
    above: sensor.ams_ec5d_p
  - trigger: time_pattern
    minutes: "1"
conditions: []
actions:
  - choose:
      - conditions:
          - condition: numeric_state
            entity_id: sensor.ams_ec5d_po
          - condition: and
            conditions:
              - condition: device
                type: is_off
                device_id: bdb56bab5f9ef9d9e0d4210ec044185f
                entity_id: 10aa6676e1da35cc7b7327853c5c5938
                domain: switch
        sequence:
          - wait_for_trigger:
              - type: power
                device_id: 3e3801cbb6ef2ff27c589980468dfc13
                entity_id: fe8147054e82cac21b29422113fe614d
                domain: sensor
                trigger: device
                above: 500
            timeout:
              hours: 0
              minutes: 5
              seconds: 0
              milliseconds: 0
          - type: turn_on
            domain: switch
      - conditions:
            below: sensor.ams_ec5d_p
          - condition: template
            value_template: >
              {{ states('sensor.nordpool_energy_prices') | float(0) >
              state_attr('sensor.nordpool_energy_prices', 'q2') | float(0) }}
        sequence:
          - type: turn_off
            domain: switch
          - delay:
              hours: 0
              minutes: 10
              seconds: 0
              milliseconds: 0
      - conditions:
            value_template: >
              {{ states('sensor.nordpool_energy_prices') | float(0) <=
        sequence:
          - type: turn_on
            domain: switch
mode: single
And the code in template.yaml for my Nordpool sensor:
        q1: >
          {% set trading_prices = (
            states('input_number.additional_energy_costs') | float(0) +
            states('input_number.elec_certificat') | float(0) +
            states('input_number.trading_fees') | float(0)
          {% set maxs = (state_attr('sensor.nordpool_kwh_se3_sek_4_10_0','max') * 125) + trading_prices %}
          {% set mins = (state_attr('sensor.nordpool_kwh_se3_sek_4_10_0','min') * 125) + trading_prices %}
          {{ (((maxs - mins) / 4 * 0) + mins) | round(2) }}
        q2: >
          {{ (((maxs - mins) / 4 * 1) + mins) | round(2) }}
        q3: >
          {{ (((maxs - mins) / 4 * 2) + mins) | round(2) }}
        q4: >
          {{ (((maxs - mins) / 4 * 3) + mins) | round(2) }}
Thanks for the inspiration!
