How can i create a (fan) switch or slide bar in HA and send ‘rest commands’ to the ITHO unit? My end goal is to have the (fan) switch or slide bar also in Homekit.
I have connected my ITHO demand flow to HA. Every room has is own valve to the mechanical ventilation. I am able to put per room the valve in ‘high’, ‘low’ or ‘auto modus’, i can send commands via a rest command:
if the valve needs to extract a lot of air, I send the following command:
http://192.168.1.117/api.html?vremotecmd=high&vremoteindex=0
if the valve needs to extract les of air (so less noise), I send the following command:
http://192.168.1.117/api.html?vremotecmd=low&vremoteindex=0
if the valve needs to extract air based on the amound of Co2 in the room, I send the following command:
http://192.168.1.117/api.html?vremotecmd=auto&vremoteindex=0
Thanks for your help!!
