Switch with REST, HTTP Post, control PoE Switch
Hey, im having problem setting up a on/off-switch for ports on my PoE Switch, it works fine with CURL with the following command:
curl -X POST -d 'method:setPoeProps&indexes=6&port=6&enabled=true' http://192.168.1.24/html/json.html
But when i try to use it in HASS i cant get it to work.
rest_command:
  my_request:
    url: http://192.168.1.24/html/json.html
    method: POST
    payload: '{"method:setPoeProps","indexes": "6","port": "6","enabled": "true"}'
How should i set up my switch?
Why did you change the payload to a dict?
shouldn’t you do it like this:
rest_command:
  my_request:
    method: POST
    payload: 'method:setPoeProps&indexes=6&port=6&enabled=true'
Well yes that worked better :wink: thanks.
