I have a 3D printer on a Smart Wifi plug, this is set up in HA and I can switch it. I have also created an automation system that turns off the printer when printing is complete. Everything was great!!
Unfortunately it has happened to me several times that I accidentally pressed the “Switch” and the printer was switched off during the printing process. Is there the possibility to set a security query, and only when this has been confirmed with “Yes” does the “plug” switch off?
I had the same problem and solved it using a button with a confirmation attached (which is not possible for a switch). I wrapped the button in a conditional card so it is only shown when the printer is on but thats not required of course. Here is the full lovelace yaml of the conditinal card (add a card and then choose ‘show code editor’ when editing it):
type: conditional
conditions:
- entity: switch.3d_printer
state: 'on'
card:
show_name: false
show_icon: true
type: button
tap_action:
action: call-service
service: switch.turn_off
service_data:
entity_id: switch.3d_printer
confirmation:
text: Are you sure you want to turn the 3D Printer off?
name: Switch 3D Printer off
icon: mdi:printer-3d-off
A less verbose option is to add a button row to an Entities card, but this will not be conditional:
type: entities
entities:
- type: button
tap_action:
service_data:
confirmation:
action_name: Turn off!
