Switch with url string
Hello, I need your help.
I have a switch that can be switched on and off via a url command.
What is the best way to integrate it into the Home Assistant
ON
http://192.168.111.171/api/v1/var/lights/item4/scmd/set?value=1&username=admin&password=admin
OFF
http://192.168.111.171/api/v1/var/lights/item4/scmd/set?value=0&username=admin&password=admin
Hi, zoogara
Can you please send me an example?
Actually - although the RESTful switch says it supports the GET method - I think you will have issues implementing it as it only supports GET for retrieving state.
The method in this post looks like it might work:
