Hi @mattsaxon,
Can you please post a link to the “TS011F by _TZ3000_typdpbpg” firmware you used?
Thanks!
Many Thanks!
It also did not start for me, I had to manually trigger it via zha.issue_zigbee_cluster_command as explained in the docs:
service: zha.issue_zigbee_cluster_command
ieee: a4:c1:38:11:2b:XX:XX:XX
endpoint_id: 1 # or endpoint_id: 3
cluster_type: out
command_type: client
cluster_id: 25
command: 0
params:
payload_type: 0
query_jitter: 100
2022-11-25 14:34:28.318 DEBUG (MainThread) [zigpy.zcl] [0xD967:1:0x0019] OTA upgrade_end handler for '_TZ3000_5f43h46b TS011F': status=Status.SUCCESS, manufacturer_id=4417, image_type=54179, file_version=192
My plug suddenly started doing this, it is recognized in zigbee2mqtt as _TZ3000_cphmq0q7.
When i check for OTA update, i get a red error message “No image available for imageType ‘5634’”.
Same, started happening recently after years of operation. Z2M 1.36.0, Zigbee Model TS011F
Zigbee Manufacturer _TZ3000_cphmq0q7
No update to anything available
I know this is an old thread but I’m trying anyway
Have tried the following
Adding:
zha:
zigpy_config:
ota:
otau_directory: /config/zigpy_ota
ikea_provider: false
ledvance_provider: false
logger:
default: info
logs:
homeassistant.components.zha: debug
zigpy: debug
ieee: a4:c1:38:fa:e7:98:4b:6c # Replace with your device's IEEE address
endpoint_id: 1 # Try 1 first, if it doesn't work, use endpoint_id: 3
cluster_type: out
cluster_id: 25
command: 0
params:
payload_type: 0
query_jitter: 100
also tried
service: zha_toolkit.ota_notify
path: /config/zigpy_ota
But I never get the:
And the device stays like so
Any suggestions?
You managed to update the _TZ3000_5f43h46b ? Can you give some details?
I usually don’t remember details after 3 years, heck I don’t remember what I had for lunch yesterday. ![]()
I still have one of these in operation and did not have any sudden turn offs since it was upgraded in Z2M.
Z2M shows the following under firmware version:
App: 0.0 build 0
Stack: 0.0 build 192
So it seems the OTA update Z2M offered 3 years ago was the latest, I don’t recall updating again after that. I have not seen any issues with this firmware version.
And yes, this is the
ZigBee Model: TS011F
_TZ3000_5f43h46b (Smart plug (with power monitoring))
(copy/paste from Z2M device details)
Hope that helps.
