Hi everyone!
I have this Switch Zigbee device integrated with ZHA in Home Assistant but for some reason it turns itself off, I turn it on and it turns off again after 2 seconds. Anyone ever happened something similar?
Tuya Smart Plug 16A EU (TS011F) Zigbee compatibility
I have two and the same thing happens with both
My ZHA coordinator is a Sonoff with Tasmota.
I also leave the firmware code of the Switch:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x010a",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0702",
"0x0b04",
"0xe000",
"0xe001"
"out_clusters": [
"0x000a",
"0x0019"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"manufacturer": "_TZ3000_cphmq0q7",
"model": "TS011F",
"class": "zigpy.device.Device"
Thanks!
