Switchbot Bluetooth devices losing contact after reboot
Is anyone else having issues with Switchbot Bluetooth sensor devices (on BT Proxy) not coming back online after Home Assistant reboot? --just says “Initializing” for very long time. I’ve also got Govee BT device, and having no issues there.
This seems to have started maybe around the time I installed HACS, &/or when I did upgrade from HA 10.x to 11.x. It’s happening across all my Switchbot BT devices (temp / humidity sensors), in multiple locations (in 2 separate buildings), connected via several different BT Proxy units (some of which are quite close to the Switchbot device).
So far, I can only get them back online after HA reboot, by a dance involving: (1) disable devices, (2) reboot HA, (3) re-add the Switchbot integration (& having it say “already installed; no configurable devices found”), (4) clicking “Show” disabled devices, then (5) re-enabling devices.
I suppose next thing to try is disabling the devices before I reboot HA, hopefully avoiding one extra reboot.
Anyone else seen this?
Must have been a bug, & now fixed. My Switchbot sensor devices are now working fine when I reboot HA, after moving to Home Assistant 2022.12.6 and BT Proxy on ESPHome 2022.12.1
