Switchbot Bluetooth Water Leak detector
Please include the water leak detector to the SwitchBot Bluetooth integration.
The API is described here:
Water leak API
Great find! From what I can see, the HA integration uses pySwitchbot to talk to the BLE accessories, so it needs to be added there beforehand. @Danielhiversen seems to be the maintainer. Let us know, if you need any data/information to make it happen :rocket:
These leak detectors seem to work really well, are inexpensive, and as they are also able to detect “dry”, for example for a fish tank, they would be a great addition to HA! For reference, we are talking about this sensor: SwitchBot Water Leak Detector
I also recently purchased a water leak detector, unfortunately, I was disappointed to see that the homeassistant couldn’t detect my new water leak sensors :frowning: I will be following up on the update here! I hope @Danielhiversen can add the connection
We have nothing new on this topic ? Get my sensors yesterday, but cant add them to HA.
Am also greatly interested by this feature.
Globally, Switchbot items are very good items.
Many thanks for feedback of any kind regarding the possible inclusion of the feature
I am a bit confused. On the webpage it says it can be connected via Bluetooth or Wifi or a SwitchBot Hub. On this webpage it is even stated it can be connected via Apple Homekit.
I mean, if Homekit would be possible, then that’s end of discussion for me because any device connected with Apple Homekit works very well (not always to full extent but since this sensor is very simple (water yes/no) I would not expect any issues here. But I don’t find anything like “Homekit compatible” on the switchbot webpage. My follow-up question would also be does it mean Homekit compatible with the Switchbot hub or the sensor alone?
So assuming there is no Homekit compatibility → back to the other options:
  • Someone stated “BLE”, which is a no-go for me
  • But it also says “Wifi” in the specs.
    → So there is my question: can this device be added to homeassistant purely using wifi? Yes/No? (no Switchbot Hub, no Bluetooth/BLE, just wifi like the shelly devices)
Other than that: anybody knows a waterleak sensor that is purely wifi (or Apple Homekit), can be added to HA, without any aquara hubs, tuya, zigbee hubs, bluetooth and so on? Second requirement: I am not the biggest fan of batteries. So if it has a battery instead of a cable it would need to be a type that can be replaced with a Batterie-AC-Adapter like all the normal batteries but NOT CR123A. I think from this point of view I only found the one from “Eve” but it’s like 90€
You should be able to add it to Home Assistant via Matter if you have a Switchbot Hub 2 or Hub Mini that is Matter supported.
As far as Bluetooth in Home Assistant, it seems this sensor defaults to WiFi if you have a WiFi connection and only drops to Bluetooth if WiFi is not available.
As was mentioned at the start of this thread, might be worth checking if it is added to pySwitchBot and if not, log a feature request on their Github site first.
Although this is bluetooth capable, if it doesn’t advertise itself and its status via BLE then it may not be able to be added to the Switchbot BLE integration in Home Assistant. The Switchbot Remote (2 button one) is another device that would be good in HA, but it doesn’t seem to advertise it’s status via BLE to allow it to be added.
@lutz85 The device is Matter compatible via the Switchbot Hub 2 or Hub Mini (Matter Enabled). I have not read anything about Homekit on Switchbot’s website, so can’t comment on that.
It will drop to Bluetooth if WiFi is not available, it does not do Bluetooth and WiFi at the same time.
How do I get this SwitchBot Water Leak Detector | Prevent Water Damage with Remote Monitoring – SwitchBot International to work with HA?
I have the matter hub mini connected to HA and it doesn’t detect it nor does it detect it via BT.
I have started to add the Switchbot Leak Detector to pySwitchbot. It is still awaiting review but could be finished soon: add Leak Detector by luc-ass · Pull Request #262 · sblibs/pySwitchbot · GitHub
After that it needs to be integrated into Home Assistant. Looks like this folder is the right place… Still have to figure that out. Can someone help out?
First of all, thanks for your work and sorry for the newbie question:
are the devices detected directly by HA now or do you have to install any integration?
As of now there is no native integration. Next steps are:
  • Merge the Leak Detector into pySwitchbot.
  • Update the dependency inside Home Assistant
  • add Leak Detector to the native integration
  • Release the updated version to the public. ETA 03.01.2025.
After that the leak detectors should be discovered automatically.
Edit: looks like some fixes are still required, but making good progress
For anyone interested, here the parts that need to fall into place (to the best of my knowledge):
Additionally:
One more quick update:
The fixes have been accepted and the Integration/Documentation have been merged. :tada: :tada: Your devices will probably show up after one of the coming updates.
I just saw the news that the Switchbot leak sensors will be supported in 2025.1 so I came looking and found this thread. The timing is great for me because I was looking into getting some leak sensors.
Just a quick thanks; I also purchased this sensor and today it triggered because a pump failed. Luckily enough I was at home at this time, but will be a great addition in HA. Thanks for your work!
Home Assistant 2025.1 is here! :partying_face:
Did it just show up? I have 2 within Switchbot app, but non showed up in HA after I installed 2025.1. Possibly a BT range issue?
Possible. Range is not great, but I have multiple Bluetooth Extenders (Shelly Plus Plug S), so they appeared immediately. Perhaps place one right next to your Bluetooth device?
Downloaded the diagnostics of the bluetooth adapter and the leak detectors mac addresses are showing, so its not a range issue…somehow they are not just showing up as new devices. Do I need to reset them or something?
I did not reset mine. Can you post the relevant data from the diagnostics? Perhaps PM me, if you feel more confident with that.
Are your Bluetooth adapters set to active?
