Do you know what is this error about? Trying to update to V.6
C:\Users\Duc\Documents\Arduino\SwitchBot-BLE2MQTT-ESP32\SwitchBot-BLE2MQTT-ESP32.ino: In function 'void setup()':
SwitchBot-BLE2MQTT-ESP32:1744:5: error: 'whiteListAdd' is not a member of 'NimBLEDevice'
NimBLEDevice::whiteListAdd(NimBLEAddress(anAddr));
SwitchBot-BLE2MQTT-ESP32:1758:5: error: 'whiteListAdd' is not a member of 'NimBLEDevice'
SwitchBot-BLE2MQTT-ESP32:1772:5: error: 'whiteListAdd' is not a member of 'NimBLEDevice'
SwitchBot-BLE2MQTT-ESP32:1786:5: error: 'whiteListAdd' is not a member of 'NimBLEDevice'
SwitchBot-BLE2MQTT-ESP32:1800:5: error: 'whiteListAdd' is not a member of 'NimBLEDevice'
Multiple libraries were found for "WiFiClient.h"
Used: C:\Users\Duc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
Not used: D:\x86\Arduino\libraries\WiFi
exit status 1
if you dont have contact or motion sensor, v5.2 is a solid version
v6.0 just came out and I donāt own contact sensors or motion sensor but got confirmation things were working from someone that does. the code needed some big changes to scan all the time. v6.0 seems to be running without issues though
the only changes in v6 for other devices would be an esp32 rssi wifi value, new HA icons and a low battery warning error
I seem to have a issue with my Meter now since upgrading to v6. 0, only seem to be populating battery and Humidity entities! No temperature and rssi link.
Tried the usual device removal in HA and reboot of espā¦
I donāt think anything changed for meter but Iāll take a look later if you are still having issues. If you are getting the attributes messages then looks like it is an MQTT discovery thing.
when the esp boots up look for the MQTT discovery message on topic homeassistant/#
I have had it where I needed to reboot HA to fix discovered devices before. give HA a reboot also
Yeh still having issues even after multiple HA reboots, addon restarts. Only Battery/Humidity entities appear.
If you wouldnāt mind double checking code.
When I get home Ill look into deeper, could just be my ever growing setup.
ya not sure. I just tried with v6 and meter works for me. I had to fake a meter though, but it shouldnāt matter. HA auto discovers no problem. The values donāt make sense so ignore those in the screenshotā¦
**edit: wait ya I found an issue where it isnāt updating meter as frequently as it should. I will fix that tonight
you shouldnāt be having an issue with auto discovery though. That part is working for me, I am just not sending the data every 60 seconds like it should. The data is only being sent when another device triggers the scan. Should be an easy fix. I will release a v6.1
At the very least you see get meter updates after an ESP32 reboot
Iāve been using this āappā for a few months with my Curtain Bots. Works really well (apart from some annoying issues with the Curtain Bots themselves).
Would it be possible for you to create releases on Github if a new version is available? Itās easier to watch for Releases on Github rather than all repo changes or this topic.
Is it possible to somehow separate the user-configurable settings from the source?
As long as no new variables are introduced that are mandatory / do not have a default value this should make upgrading a lot easier.
I havenāt separated the files because of that reason. I am still adding new variables and donāt want people to have issues mixing up files etc. When switchbot releases documentation for new devices I need new variables. In v6 I actually just fixed some variables by adding āconstā to save memory. Diagnosing those issues with someone elseās setup would be a pain for me. 1 file makes it simple.
The code by default, does a scan every minute for the meter bot? I thought it does not and I have been add`ing it manually from here. I do not need it?
Are you on v6.0 and seeing any issue with your meter?
Im adding a 30 sec scan Interval to my meter but I do not think it makes any difference.
You are right, default seems to scan every minute, with temperature its clear to see.
I am on V6.0 and I donāt think I am having any issue as you described above. Though I had manually created mqtt sensors for batteries in the pass and now since it has been added by default, I noticed there are 2 sensors with same names. Anyways, I will fix this. Here is my meter. Seems ok and all there. The firmware maybe an issue. The other unknown maybe normal since the meter does not support it?
