The 1st screenshot above entities were created by mqtt discovery. You should have the same count of entities as mine.
Yours shows as a bot not a meter?!
That is strange. I checked the code and I have added the meter mac in the correct area. Not sure why mine is showing a bot.
/* Switchbot Meter Settings */
static std::map<std::string, std::string> allMeters = {
{ "meter", "c2:76:p5:98:68:ad" }
if you compile once with meter mac in the bot list then itll do that. just delete the device and reboot. not a big deal
but ya there is a metervbug for sure in v6.0. ill release in a bit, just testing to be sure
Oh. I didnāt realized I had placed it in the bot at one point. I will do that on my next reboot of HA.
v6.1 is released. should fix the meter not auto scanning issue
ya I double checked and nothing changed with meter discovery since v5.2 and it works for me. the method is publishHomeAssistantDiscoveryMeterConfig
in the code
Try v6.1. not sure what went wrong, but I assume itāll start working again with v6.1
by default it will use defaultMeterScanSecs = 60
to scan for ALL meters every 60 secs
if you had one meter that you wanted to scan more often (like every 30 sec), you could add it to the botScanTime list
static std::map<std::string, int> botScanTime = {
{ "meterone", 30 }
you can scan as often as you want, technically it just means the esp32 uses a bit more power
Hey everyone, sorry a small bug was found in v6.1. v6.2 released
The curtain cover entity was not being created by auto discovery. I didnāt leave enough buffer space for the cover entity mqtt message. in v6.1 it is 512, it is set back to 1024 in v6.2
@TeaMan this couldāve also affected meter and maybe why you had discovering meter devices
cheers
Good stuff Thanks for letting me/us know. And nice one for finding!
Ill upgrade at some point.
Ah, I was about to comment about not having any cover entities show up in autodiscovery. Iāve upgraded to 6.2 and unfortunately Iām still not seeing themā¦
Iām seeing the other 5 entities that get created with autodiscovery.
I just retried to confirm and all good from my side. deleted the device, rebooted esp32, then they show up after 30 secs or so
maybe your 6.2 update didnāt go through? does the OTA webpage show 6.2?
you should see 6 entities on a curtain device:
- battery
- calibrated
- curtain (cover)
- illuminance
- linkquality
- position
(Ignore the values, they are incorrect because I donāt own curtain and I am faking one)
Hi devWaves,
Looks good on v6.2 for Bots and METER, Well-done!
My Curtain bots arenāt attached to this ESP32 so canāt test for that.
At some point Iāll update the Curtain ESP32ā¦
Ah, that was it. Pretty embarassing on my end. I was using the arduino-cli to try to upgrade, didnāt think of checking the OTA webpage to check. Used it to flash the new image and now Iām on 6.2 with cover entities.
They seem to be working, the device is doing a lot of scanning at the moment for some reason (the blue led is on a lot) so actions are a bit slow, but Iāll look into that myself.
Thanks a lot (again)!
cool. ya no problem. if you are using motion and/or contact sensor the LED will be on all the time by default because it scans all the time
if you only have bot/meter/curtain then you should see the scanning stop. based on the number of devices.
the scanning should not affect the speed of control ( it did in previous older versions). whenever scanning and a control/set is received, it should immediately stop scanning, then perform the actionā¦ no noticeable delay
make sure you have good linkquality RSSI values for each devices. Scanning can be done with a bad signal, control is best to be at least -75 ish
if you can get an rssi around 40-50-60 then that is a good connection. The worse the signal, the longer it takes to control
I just noticed that SwitchBot released BLE documentation for their new upcoming color bulb (not even sure if it is released yet)
If anyone ends up getting one and wants me to add support for it, just give me a shout. Seems like it would be pretty straight forward to implement. I would need a tester
Cool. Not for me, Iām well and truly in the Hue eco system.
Wish Switchbot would design some sort of blind controller though, just tilt adjustment would be nice and all running off esp32ās!
It was brought to my attention that the curtain cover MQTT discovery message did not associate the state PAUSE to the closed state. The call would work, but would generate a warning like this in HA logs
Payload is not supported (e.g. open, closed, opening, closing, stopped): PAUSE
a very minor change was added and released as v6.3 to fix this
For those that prefer using PlatformIO instead of the Arduino IDE, I have released a v6.4
There are no functional differences between v6.4 and v6.3, so if you are already running v6.3 there is no need to update to v6.4
Cheers
A request to support the remote button was made in github hereā¦
devWaves Github - Remote Support Link
Edit: it looks like the switchbot remote up/down actions cannot be supported because of how it works. The remote links directly with a bot or curtain and does not advertise this data. The remote only seems to advertise battery level. I may still add it as a possible device to monitor battery through MQTT, but the up/down actions cannot be captured
