Switchbot - camera/motion sensor integrations
I can’t see anything else except the switch integration.
I was looking to pause media, check motion in rooms and all that but can’t see any support. Even Switchbot button presser, I needed to use webhooks instead of the integration via IFTT.
If Switchbot is not suitable for this, can someone recommend motion sensors?
The camera/motion hardware from switchbot is pretty new, first it needs someone who owns them, has the coding skills and is willing to write the integration. You should add this as a feature request.
I added motion sensor and contact sensor to v6.0 of my esp32 switchbot implementation
https://community.home-assistant.io/t/switchbot-bot-curtain-meter-contact-motion-mqtt-esp32-bridge-local-control
well i own switchbot cameras, i own a little coding skills not able to create this integration alone but i can help
