Switchbot Curtain
Once or while the integration is installed bring the Curtainbot into pairing mode, then it should be detected.
But make sure you first have removed your manually added lines in the configuration.yaml and restart HA.
You donā€™t need to put the curtain in pairing mode, ha will discover them automatically.
I have my switchbot curtain connected with the new bluetooth integration in 2022.8. I recive all the information but i dont seem to be able to control the device. The slider nor the open or close button does anything. If i control the curtain with the app de status in HA is updating so there is communication.
Does anyone have the same issue and any tips to resolve this?
Have a search on here, thereā€™s a few people with the same issue
A figured it out. It was the issue with the password. didnt see that before
Best,
I have removed everything from switchbot from the configuration.yaml. But when I start the integration I immediately get ā€œNo unconfigured devices foundā€. The switchbot Curtain blinks.
I assume you have the curtains set up and working in the Switchbot app ? Once its working there, donā€™t put it in pairing mode, install the integration in HA and theyā€™ll be discovered.
I apologize for replying to an old thread and this isnā€™t about the Switchbot Curtain, but the Switchbot Motion sensor; however, Iā€™m experiencing the same Bluetooth issues as others have reported and the solution seems like it would work for the motion sensor as well. But, I have HA installed as a VM on my Synology NAS and have very little experience with Raspberry Pi and still trying to figure out exactly what ESP32 is, so I apologize for the newb question here.
Basically, I was hoping someone could recommend the hardware theyā€™d recommend so that HA can access the motion sensor. Iā€™m honestly a bit disappointed that it doesnā€™t connect to the hub and use Switchbotā€™s connection, but oh well. I should have gone with a Z Wave or Zigbee Motion Sensor, but I donā€™t have experience with either of those yet (Iā€™m slowly moving away from cloud-based smart home devices).
So, from my understanding in this thread (and others around the internet), I have a few options. Iā€™m going to exclude Raspberry Pi devices (even the Zeroā€™s) as theyā€™re ridiculously priced right now.
Possible Solutions
Single Board PCs
More of a DIY option and would require some level of configuration & tinkering
Smart Home Hubs
While these would still rely on an internet connection, Iā€™m fine with that. However, basically these hubs would, from my understanding, connect to Switchbot and then relay that connection back to HA.
The main problem is that my room/office is almost like a faraday cage. The walls are cinder block and metal sheetsā€¦ so my house is mostly run with ethernet over MoCA to wireless AP. Iā€™m afraid that getting a Zigbee or Z Wave device Iā€™ll run into the same issues as Bluetooth, but perhaps Iā€™m wrong about that? If so, should I just return the Switchbot Motion Sensor and go with something like the YoLink Hub & Sensor, Aqara, or whoever?
I apologize for all the questions and linksā€¦ Iā€™m just really lost about what hardware would serve me best and one thing Iā€™ve learned since starting my homelab journey about two years ago are that buying the wrong equipment/networking mistakes are very costly, so Iā€™m just weary of purchasing something I donā€™t understand very well.
Thank you for your time!
AJ
PS: Sorry I couldnā€™t link to all the hardware, Iā€™m limited to only posting two links as a new user.
Have you looked at this option yet?
You will need an esp32 board.
Have Mqtt installed and configured in HA.
Have Arduino install on your PC or mac. This is to upload the code to the esp32 board.
Place the esp32 board in bluetooth range to the motion sensor and in wifi range to esp32 board.
I do not have the switchbot motion sensor, but have the door sensor. It takes anywhere between 1-2 seconds. Depending on what you want to trigger, it maybe too long if you are using it to turn on lights. Zigbee or wifi motion sensor device would be faster, however.
Use what you have and give it try. Esp32 is quite cheap if you are willing to wait for the delivery time, but it is still inexpensive if you get it from Amazon.
Hi, Iā€™m confused. I added 2 switchbot curtain 3 to my HA. I have both in Integration entries but I dont know how I can control themā€¦
Each has these sensors: Sensors
Contact Sensor 3041
Clear
Contact Sensor 3041
Closed
Light
No light
