Hi all,
Using the switchbot integration with Hub to control curtains (2 switchbot curtain bot U-rail 2)
Once in a while, I got following error:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/switchbot/cover.py:110
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 22:12:36 (2 occurrences)
Last logged: 22:12:38
[140653044020320] Bluetooth command failed (code: 2, error: Attribute can't be read)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 193, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1704, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1741, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 964, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 717, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/switchbot/cover.py", line 110, in async_close_cover
await self.hass.async_add_executor_job(self._device.close)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/switchbot/__init__.py", line 648, in close
result = self._sendcommand(CLOSE_KEY, self._retry_count)
File "/usr/local/lib/python3.9/site-packages/switchbot/__init__.py", line 418, in _sendcommand
notify_msg = self._readkey()
File "/usr/local/lib/python3.9/site-packages/switchbot/__init__.py", line 386, in _readkey
read_result: bytes = char.read()
File "/usr/local/lib/python3.9/site-packages/bluepy/btle.py", line 197, in read
return self.peripheral.readCharacteristic(self.valHandle)
File "/usr/local/lib/python3.9/site-packages/bluepy/btle.py", line 530, in readCharacteristic
resp = self._getResp('rd')
File "/usr/local/lib/python3.9/site-packages/bluepy/btle.py", line 407, in _getResp
resp = self._waitResp(wantType + ['ntfy', 'ind'], timeout)
File "/usr/local/lib/python3.9/site-packages/bluepy/btle.py", line 368, in _waitResp
raise BTLEGattError("Bluetooth command failed", resp)
bluepy.btle.BTLEGattError: Bluetooth command failed (code: 2, error: Attribute can't be read)
Anyone seen this before ?
Thanks !
B.
