Hello people
unfortunately I have a problem and today I tried to start up my Switchbot.
I wanted to integrate the HUB as well and therefore I installed python-switchbot via the terminal.
Now the whole thing did not work and I wanted to add this via the standard integration via switch.
but now I doesn’t work, is it not possible to use espresence and switch bot together via Bluetooth?
how can I fix this again? Is there a simple way to do this?
Thanks a lot
PS: Is it possible to restore the default integration?
now I got this message:
This integration does not support configuration via the user interface. If you followed this link from the Home Assistant website, make sure you are running the latest version of Home Assistant.
