when adding the integration, it just fails with unexpected error
2022-07-30 06:03:39 ERROR (MainThread) [homeassistant.components.switchbot.config_flow] Unexpected exception stderr
23:03:39 Traceback (most recent call last): stderr
23:03:39 File “/usr/src/homeassistant/homeassistant/components/switchbot/config_flow.py”, line 89, in async_step_user stderr
23:03:39 self._discovered_devices = await self._get_switchbots() stderr
23:03:39 File “/usr/src/homeassistant/homeassistant/components/switchbot/config_flow.py”, line 55, in _get_switchbots stderr
23:03:39 _btle_adv_data = await _btle_connect() stderr
23:03:39 File “/usr/src/homeassistant/homeassistant/components/switchbot/config_flow.py”, line 34, in _btle_connect stderr
23:03:39 switchbot_devices = await GetSwitchbotDevices().discover() stderr
23:03:39 File “/usr/local/lib/python3.10/site-packages/switchbot/init.py”, line 167, in discover stderr
23:03:39 await devices.start() stderr
23:03:39 File “/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/scanner.py”, line 88, in start stderr
23:03:39 self._bus = await MessageBus(bus_type=BusType.SYSTEM).connect() stderr
23:03:39 File “/usr/local/lib/python3.10/site-packages/dbus_next/aio/message_bus.py”, line 122, in init stderr
23:03:39 super().init(bus_address, bus_type, ProxyObject) stderr
23:03:39 File “/usr/local/lib/python3.10/site-packages/dbus_next/message_bus.py”, line 85, in init stderr
23:03:39 self._setup_socket() stderr
23:03:39 File “/usr/local/lib/python3.10/site-packages/dbus_next/message_bus.py”, line 575, in _setup_socket stderr
23:03:39 raise err stderr
23:03:39 File “/usr/local/lib/python3.10/site-packages/dbus_next/message_bus.py”, line 548, in _setup_socket stderr
23:03:39 self._sock.connect(filename) stderr
23:03:39 FileNotFoundError: [Errno 2] No such file or directory
