SwitchBot integration stopped working since 0.118.5
SwitchBot integration has been causing the Switch integration to crash since I updated my hassio core to 0.118.5. This also causes the Check Configuration (in Configuration panel) to hang forever, and hassio no longer restarts through the Server Controls RESTART button, it basically just hangs in there forever as well (I have to switch my RPi4 completely off and on to restart it).
The only fix so far seems to be to disable all switchbot instances in the configuration.yaml
Anyone experiencing the same issues ?
What do the logs say?
It seems to be an indentation issue that didn’t use to get picked up with the switchbot integration
