Hello
I have connected my switchbot and it works fine for the first 5 minutes and after that it keeps disconnecting the error log is below:
File "/usr/src/app/homeassistant/components/websocket_api/commands.py", line 122, in handle_call_service
connection.context(msg))
File "/usr/src/app/homeassistant/core.py", line 1138, in async_call
self._execute_service(handler, service_call))
File "/usr/src/app/homeassistant/core.py", line 1160, in _execute_service
await handler.func(service_call)
File "/usr/src/app/homeassistant/helpers/entity_component.py", line 188, in handle_service
self._platforms.values(), func, call, service_name
File "/usr/src/app/homeassistant/helpers/service.py", line 314, in entity_service_call
future.result() # pop exception if have
File "/usr/src/app/homeassistant/helpers/service.py", line 328, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/usr/src/app/homeassistant/components/switchbot/switch.py", line 55, in turn_on
if self._device.turn_on():
File "/config/deps/lib/python3.7/site-packages/switchbot/__init__.py", line 59, in turn_on
return self._sendpacket(ON_KEY)
File "/config/deps/lib/python3.7/site-packages/switchbot/__init__.py", line 50, in _sendpacket
if retry < 1 or not self._connect():
File "/config/deps/lib/python3.7/site-packages/switchbot/__init__.py", line 36, in _connect
bluepy.btle.ADDR_TYPE_RANDOM)
File "/config/deps/lib/python3.7/site-packages/bluepy/btle.py", line 391, in __init__
self._connect(deviceAddr, addrType, iface)
File "/config/deps/lib/python3.7/site-packages/bluepy/btle.py", line 433, in _connect
self._writeCmd("conn %s %s\n" % (addr, addrType))
File "/config/deps/lib/python3.7/site-packages/bluepy/btle.py", line 305, in _writeCmd
self._helper.stdin.flush()
BrokenPipeError: [Errno 32] Broken pipe
The above error keeps recurring if I was to turn the switch on/off from HA.
@Danielhiversen can you please look into it? Do we have to connect it to Bluetooth on the device running HA?
