Switchbot Lock "Retract Deadbolt" Action?
I have just purchased and setup the Switchbot Lock and from the Switchbot app it works great.
It also works great through the HA integration, except I have a lock which has two “actions” when I click to unlock which are setup in the Switchbot app as “Unlock” or “Retract Deadbolt”…
Basically my lock has a deadbolt and then to actually “unlock” I have to slightly twist the key a bit further to unlatch the door, Switchbot mimics this extra unlatching now…
It looks like this has only been introduced on the lock recently (Reference Setup Forum Post)
The HA “Unlock” just performs the standard unlock, but with my specific door unless I pull the handle down after retracting the deadbolt it thinks it “jams”, where in reality in just can’t turn the last couple of mm to unlatch, so was looking for the ability to lock, unlock or just retract the deadbolt…
Anyway, my question is if the “Retract Deadbolt” option is (or will be) available in the integration, rather than just unlock & lock?
I am not sure if it is part of the api yet, so may not even be possible at all yet, but thought I would ask?
Same problem here. Try Found solution
EDIT: remove and add lock and appear button to unlatch
Can you explain a little better?
Do you have a solution or not?
