Running HA vm supervised using proxmox. I have the SwitchBot integration running with no errors and I can see my SwitchBot bot. I can also control it ( although it takes about 10 seconds ) but I can’t figure out how to make it show as toggles instead of lightning
bolts.
Its shown like that due to the state of the attribute- assumed_state: true
To change it use Customize, but just remember if you change it to false and get the toggle icon you’ll never definitively know the state of the switch you are controlling, if someone pushes the switch manually the state will be wrong.
You could also try changing the Mode of the switch in the app.
