I’m using the Switchbot integration with multiple sensors (using bluetooth only as I have removed using the Switchbot hub). I have just recently added a number (4) of the plug minis. I did this by adding them by 1st adding them to the Switchbot app and then once they showed up in HA, configuring them as necessary. I used the last 4 of the BLE MAC id in the app to compare which plug I was setting up.
Ever since I started adding these plugs, I get multiple additional of the same device (just with a different id) being discovered. I can’t find any correlation between the ids of these newly discovered devices and the ones I’ve already set up. At first I just tried “ignoring” these, but now that I have 4 plugs setup, these newly discovered devices have multiplied (I’ve had 28 new “discovered” Plug Minis just in the past few hours.
Any suggestions on what I can do?
thanks!
