I get the distinct feeling that switchbot is no longer supported within Hassio. Is there any way to find out if this is the case?
I’m having issues with mine. This is the error. I have no idea where to start!
Thu Mar 07 2019 19:36:45 GMT+0000 (Greenwich Mean Time)
'NoneType' object has no attribute 'getServiceByUUID'
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/websocket_api/commands.py", line 148, in handle_call_service
connection.context(msg))
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1133, in async_call
self._execute_service(handler, service_call))
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1155, in _execute_service
await handler.func(service_call)
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_component.py", line 188, in handle_service
self._platforms.values(), func, call, service_name
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 278, in entity_service_call
future.result() # pop exception if have
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 292, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/switch/switchbot.py", line 48, in turn_on
if self._device.turn_on():
File "/usr/local/lib/python3.7/site-packages/switchbot/__init__.py", line 59, in turn_on
return self._sendpacket(ON_KEY)
File "/usr/local/lib/python3.7/site-packages/switchbot/__init__.py", line 45, in _sendpacket
hand_service = self._device.getServiceByUUID(UUID)
AttributeError: 'NoneType' object has no attribute 'getServiceByUUID'
Just tried removing the name element too, but still no joy.
Getting this error on Hassio startup:
2019-03-08 14:23:44 ERROR (SyncWorker_14) [switchbot] Failed to connect to switchmate
File "/usr/local/lib/python3.7/site-packages/switchbot/__init__.py", line 36, in _connect
bluepy.btle.ADDR_TYPE_RANDOM)
File "/usr/local/lib/python3.7/site-packages/bluepy/btle.py", line 353, in __init__
self._connect(deviceAddr, addrType, iface)
File "/usr/local/lib/python3.7/site-packages/bluepy/btle.py", line 402, in _connect
"Failed to connect to peripheral %s, addr type: %s" % (addr, addrType))
bluepy.btle.BTLEException: Failed to connect to peripheral fe:f9:c3:5f:8f:f6, addr type: random
