I’d love to use my SwitchBot Remote button to run HomeKit scenes or even just change the status of devices in HASS. Is this something that could be added to the SwitchBot integration? IFTTT doesn’t seem to have a trigger for when the button is pressed, so no workaround there.
Why can’t you do that with an automation?
What would that look like? I’m not sure how the button press would leave the SwitchBot Hub and be picked up by HASS or anything else.
You use this integration to get your switchbot into home assistant as a switch:
Does that also work with this product? I was under the assumption that the above integration was only for the “button pusher” product.
Ah I see. I thought you had the switch. You could try it an see.
Thought I might revive this now Bluetooth is so advanced in Home Assistant now.
Switchbot have a 2 button remote control called a Switchbot remote. If this request was not for that device, or similar device, then let me know.
I see plenty of uses for this remote, including on/off for lights, fans, etc or even for controlling windows/blinds or for setting temperatures for thermostats remotely.
Lots of uses.
Same here … whould be nice to use the two Buttons of the SwitchBot Remote inside Home Assistant.
- 1 for getting the switchbot remote (two button remote) into Home Assistant. SwitchBot Remote | Turn on/off Your SwitchBot Smart Devices – SwitchBot International
Has anyone found any work around or an alternative remote button even ?
I want to use Switchbot button for trigger of automation by integration.
Plz someone add function to integration. ![]()
+1 willing to pay to get this integration:)
I’ve added lots of switchbot items to my home over the last year and they all just worked (except for the button on the door sensor…), so I didn’t even check if these Remotes would work before buying 5… I would be thrilled to get these working within Home Assistant!
I got the remote connected to Home Assistant. But it only shows the battery state and no button or input entities. ![]()
I just got 3 of those as well, assume they would just work, because all of my SwitchBot Curtains integrates smoothly. But I can also only get to pick the battery percentage within the automation creator.
Would be amazing to get this functionality in the next update. <3
The remotes were added quite recently, and the docs stated that (for now?) it was only battery state, not button events. You can link the remotes to a curtain using the Switchbot app (and see the effect on the curtain caused by the button). But for now you cannot use the buttons separately to control things trough HA automations. Homefully at some point that will come.
I linked the remotes to the curtains. That way I can still operate the curtain when HA or the integration is down for some reason.
