I flashed three Sonoff basics and four KULED WiFi switches with esphome firmware. For the most part, everything is working as expected, however I’ve noticed when the lights are on, every minute or two you here the relay click and the lights flicker. It’s as if a blip in WiFi causes the light to turn off and it recovers back to the last state. Everything shows up and functions properly in HA although you can see this light flicker in HA and in the device status.
Here is a sample yaml:
esphomeyaml:
platform: ESP8266
board: esp01_1m
board_flash_mode: dout
wifi:
ssid: XXXX
password: XXXX
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.0.223
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.0.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
This is the watchdog logic for MQTT and API.
For MQTT, if the ESP can’t connect to the broker within 5 minutes, it reboots.
For API, if no client (like Home Assistant) connects to the ESP within 5 minutes, it also reboots.
I think the issue here is that:
a) You disabled your MQTT broker after upgrading to native API?
b) You have Home Assistant configured to connect to the ESP via MQTT, not API. So then no client connects to the native API and thus the ESP reboots every 5 minutes.
(You can read all about the reason for this watchdog logic in the docs. Look for reboot_timeout)
Thanks for the quick response. I do have them set up to MQTT because I was getting mixed results when trying to use them via the API. Namely in HA when I would go to configure them, it keeps saying my password is invalid. Also, I can’t get to them via the .local address only by direct IP. Is the preferred method the native API and I should disable MQTT and figure out my issues?
I commented out the MQTT config and uploaded to the devices. I was then able to fully configure them in the Native API and all appears to be working as expected. Thank you for steering me in the right direction and thank you for all of your amazing work on this project!!!
I also have odd results. I try to esplain: yesterday I update ESPHome from a previous version with MQTT autodiscovery to the last version with native API.
I already removed the mqtt section from yaml configuration and I used also the “clean-mqtt” command to remove any mqtt message on the broker, then restarted HA a couple of times.
HA correctly find the device by the integration panel, but it’s not reliable, because the device goes “unavailable” very often.
Also with the esphome dashboard I have same behaviour:
INFO Reading configuration...
INFO Starting log output from 192.168.6.137 using esphomelib API
INFO Connecting to 192.168.6.137:6053 (192.168.6.137)
INFO Successfully connected to 192.168.6.137
[10:26:42][I][application:097]: You're running esphomelib v1.10.1 compiled on Feb 5 2019, 22:47:00
[10:26:42][C][wifi:341]: WiFi:
[10:26:42][C][wifi:240]: SSID: 'martinRoutero'
[10:26:42][C][wifi:241]: IP Address: 192.168.6.137
[10:26:42][C][wifi:243]: BSSID: 18:D6:C7:FC:F9:41
[10:26:42][C][wifi:245]: Hostname: 'lampadaluigi'
[10:26:42][C][wifi:250]: Signal strength: -83 dB ▂▄▆█
[10:26:42][C][wifi:251]: Channel: 6
[10:26:42][C][wifi:252]: Subnet: 255.255.255.0
[10:26:42][C][wifi:253]: Gateway: 192.168.6.1
[10:26:42][C][wifi:254]: DNS1: 0.0.0.0
[10:26:42][C][wifi:255]: DNS2: 0.0.0.0
[10:26:42][C][binary_sensor.status:046]: Status Binary Sensor 'Lampada Luigi Status'
[10:26:42][C][binary_sensor.status:046]: Device Class: 'connectivity'
[10:26:42][C][binary_sensor.gpio:023]: GPIO Binary Sensor 'Lampada Luigi Button'
[10:26:42][C][binary_sensor.gpio:024]: Pin: GPIO0 (Mode: INPUT_PULLUP, INVERTED)
[10:26:42](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[10:26:42][C][output.esp8266_pwm:028]: ESP8266 PWM:
[10:26:42][C][output.esp8266_pwm:029]: Pin: GPIO13 (Mode: OUTPUT, INVERTED)
[10:26:42][C][output.esp8266_pwm:030]: Frequency: 1000.0 Hz
[10:26:42][C][logger:099]: Logger:
[10:26:42][C][logger:100]: Level: VERBOSE
[10:26:42][C][logger:101]: Log Baud Rate: 115200
[10:26:42][C][light.state:266]: Light 'Lampada Luigi Green LED'
[10:26:42][C][light.state:268]: Default Transition Length: 1000 ms
[10:26:42][C][light.state:269]: Gamma Correct: 2.80
[10:26:42][C][switch.restart:034]: Icon: 'mdi:restart'
WARNING Disconnected from API.
WARNING Couldn't connect to API (Error connecting to 192.168.6.137: timed out). Trying to reconnect in 1 seconds
WARNING Couldn't connect to API (Error connecting to 192.168.6.137: timed out). Trying to reconnect in 2 seconds
WARNING Couldn't connect to API (Timeout while waiting for message response!). Trying to reconnect in 4 seconds
WARNING Couldn't connect to API (Already connected!). Trying to reconnect in 8 seconds
WARNING Couldn't connect to API (Timeout while waiting for message response!). Trying to reconnect in 2 seconds
WARNING Couldn't connect to API (Already connected!). Trying to reconnect in 4 seconds
[10:28:02][D][api:241]: 'Home Assistant 0.86.4 (192.168.6.245)' disconnected.
[10:28:09][V][api:500]: Hello from client: 'Home Assistant 0.86.4 (192.168.6.245)'
[10:28:09][D][api:531]: Client 'Home Assistant 0.86.4 (192.168.6.245)' connected successfully!
I was wondering if it possible to keep the Sonoff Basic’s green led on after a light.turn_on action is called?
Basically I want to keep the LED on if the main relay is on and then turn it off when relay is off. This is my code:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: ${wifi_ssid}
password: ${wifi_psw}
fast_connect: true
ap:
ssid: ${friendly_name}
password: ${ap_psw}
logger:
web_server:
api:
password: ${api_psw}
ota:
binary_sensor:
## Buton 00
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 400ms
then:
- switch.toggle: main_switch
- timing:
- ON for at most 1s
- OFF for at most 399ms
- ON for at most 1s
then:
- text_sensor.template.publish:
state: "button_pressed"
- delay: 50ms
state: "button_00_double"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_00_triple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_00_quadruple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_00_many"
- timing:
- ON for at least 2s
then:
- delay: 50ms
state: "button_00_long"
output:
- platform: gpio
pin: GPIO12
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
switch:
- platform: output
output: main_relay
icon: ${switch_icon}
on_turn_on:
then:
- light.turn_on: led
on_turn_off:
then:
- light.turn_off: led
light:
- platform: monochromatic
output: basic_green_led
- platform: wifi_signal
name: ${friendly_name} - Sinal Wifi
update_interval: 60s
text_sensor:
name: ${friendly_name} - Interruptores
icon: "mdi:light-switch"
status_led:
pin:
number: GPIO13
inverted: true
With this code, when I turn on the switch, relay turns on, led fades in and immediately turns off. When switch is turned off, relay goes off, led turns on and fades out.
