Switched und outlet-metered 19" rack-mount PDU supported by Home Assistant?
I am currently looking into a power supply for my 19" server rack that supports outlet-metered (measure power consumption on each port individually) and switchable (on/off control for each port) via IP and is easy to integrate into home assistant?
Hardware-wise I found GUDE products that support my needs … but I am not sure about how to integrate them into HA…
I prefer CyberPower PDU’s, though, and if you want to integrate those, you may have to use SSH, perhaps via SSH Integration - Connect your servers to Home Assistant
Managed to integrate the GUDE PDU … works with MQTT!
i have a gude pdu too, how did you do it?
thanks a lot for your feedback
i have got a older one
the Gude Expert Power Controll 8220
think i will have to go over snmp
… or try contact GUDE support. They have been super helpful in my case.
Did they sent you a new inoffical Firmware with MQTT Support for the 8220?
The last Firmware available for the 8220 on their Website is from 2017.
No I have the Expert Power Control 8045-1 (v1.4.1-R2). I think they did send me a preview firmware but it is now public.
For older models maybe inquire them directly.
