I have a Switcher device (V2) and it’s working fine with the built-in Switcher component.
Last week I bought the Switcher Power Plug that actually uses the same protocol,
but I can’t define both of them together.
I did manage to define both of the devices using the previous custom component
@TomerFi do you know if the built-in switcher_kis component can support multiple devices?
Hi Yoni,
I used Switcher heater custom component instead of switcher_kis.
In the custom component you can define multiple devices.
you can find the custom component here:
Has anyone been able to connect a switcher power plug and query it for energy readings in home assistant?
I’m trying to get a notification when the device plugged it turns off
