I was wondering if this is the place to suggest the development of a new component for the Switcher which is a boiler smart switch
I’ve ran into an Alexa skill published to GitHub and am new to Python development
Would be glad to receive some guidance on adapting the existing code to Python
I just did some more research and found this Python API which seems to work
Which type of component should I look at that would be of the same usage as the switcher ?
I’m pretty new to Python development (coming from Java) so I might not understand everything explained on the first shot
Thanks for that @fabaff
I ended up using the Python API linked above together with a command line switch as per the API’s author (Gal Golan) suggestion: https://pastebin.com/DPcHetKb
I’ll keep your suggestion though to a time I’ll be more available to create a component for this switch
Thanks a lot for your time and guidance
Getting started with it is the hardest thing basically; I configured an automation for the Switcher workflow for auto-starting on cloudy days but obviously the best solution would be for a new type of climate device
