hello,
upgraded to the latest HAS version, my switches defined in configuration.yaml disappeared from web UI, any idea why? thanks
looks like that
hello,
looks like that
can anyone advice what happened here? thanks
Look in your logs for errors and correct the errors. There should be something if that setup failed. When it doubt, always consult your logs first and provide them with posts if you still need help.
@petro sorry my fault, i can see only
2022-04-25 13:48:45 ERROR (SyncWorker_5) [homeassistant.components.orvibo.switch] S20 at 10.0.1.38 couldn’t be initialized
2022-04-25 13:48:48 ERROR (SyncWorker_5) [homeassistant.components.orvibo.switch] S20 at 10.0.1.39 couldn’t be initialized
Verify that those IPs still exist through your router.
@petro thanks, both dead ;-( appreciate.
ouch, dead or just need to be reset?
