log recorded directly after flashing:
i:141]: Using noise encryption: YES
53
[C][ap32
load:0x40080400,len:3036
entry 0x400805e4
[ 6][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[I][logger:262]: Log initialized
[V][esp32.preferences:059]: nvs_get_blob('233825507'): ESP_i:141]: Using noise encryption: YES
[D][api:102]: Accepted 192.168.188.100
[W][api.connection:075]: 192.168.188.100: Socket operation failed: BAD_INDICATOR errno=11
[V][api:114]: Removing connection to 192.168.188.100
[V][api.connection:941]: Hello from client: 'aioesphomeapi (192.168.188.100)' | API Version 1.7
[W][api.connection:087]: aioesphomeapi (192.168.188.100): Connection closed
[V][api:114]: Removing connection to aioesphomeapi (192.168.188.100)
[V][api.connection:941]: Hello from client: 'Home Assistant 2023.6.1 (192.168.188.100)' | API Version 1.7
[D][api.connection:959]: Home Assistant 2023.6.1 (192.168.188.100): Connected successfully
[D][api.connection:163]: Home Assistant 2023.6.1 (192.168.188.100) requested disconnected
[V][api:114]: Removing connection to Home Assistant 2023.6.1 (192.168.188.100)
[288717][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: FRITZBox-7590-5193180, BSSID: 3c:37:12:4b:39:76, Reason: 34
[288718][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
[288726][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 34 - STA_STOP
[W][wifi_esp32:504]: Event: Disconnected ssid='FRITZBox-7590-5193180' bssid=3C:37:12:4B:39:76[redacted] reason='Unspecified'
[W][wifi:126]: WiFi Connection lost... Reconnecting...
[I][wifi:258]: WiFi Connecting to 'FRITZBox-7590-5193180'...
[V][wifi:260]: Connection Params:
[V][wifi:261]: SSID: 'FRITZBox-7590-5193180'
[V][wifi:264]: BSSID: 3C:37:12:4B:39:76
[V][wifi:284]: Password: '84Ax&921727Po2764'[redacted]
[V][wifi:289]: Channel: 6
[V][wifi:296]: Manual IP: Static IP=192.168.188.103 Gateway=192.168.188.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0
[V][wifi:300]: Hidden: NO
[V][component:204]: Component wifi took a long time for an operation (0.05 s).
[V][component:205]: Components should block for at most 20-30ms.
[W][api.connection:062]: Home Assistant 2023.6.1 (192.168.188.100): Network unavailable, disconnecting
[288905][V][WiFiGeneric.cpp:353] _arduino_event_cb(): STA Connected: SSID: FRITZBox-7590-5193180, BSSID: 3c:37:12:4b:39:76, Channel: 6, Auth: WPA2_WPA3_PSK
[288908][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 4 - STA_CONNECTED
[288911][V][WiFiGeneric.cpp:367] _arduino_event_cb(): STA Got Same IP:192.168.188.103
[V][wifi_esp32:487]: Event: Connected ssid='FRITZBox-7590-5193180' bssid=3C:37:12:4B:39:76[redacted] channel=6, authmode=UNKNOWN
[288943][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 7 - STA_GOT_IP
[288943][D][WiFiGeneric.cpp:991] _eventCallback(): STA IP: 192.168.188.103, MASK: 255.255.255.0, GW: 192.168.188.1
[V][wifi_esp32:546]: Event: Got IP static_ip=192.168.188.103 gateway=192.168.188.1
[I][wifi:519]: WiFi Connected!
[C][wifi:363]: Local MAC: C8:F0:9E:F4:52:04
[C][wifi:364]: SSID: 'FRITZBox-7590-5193180'[redacted]
[C][wifi:365]: IP Address: 192.168.188.103
[C][wifi:367]: BSSID: 3C:37:12:4B:39:76[redacted]
[C][wifi:368]: Hostname: 'hoftor'
[C][wifi:370]: Signal strength: -63 dB ▂▄▆█
[V][wifi:372]: Priority: -2.0
[C][wifi:374]: Channel: 6
[C][wifi:375]: Subnet: 255.255.255.0
[C][wifi:376]: Gateway: 192.168.188.1
[C][wifi:377]: DNS1: 0.0.0.0
[C][wifi:378]: DNS2: 0.0.0.0
[D][wifi:528]: Disabling AP...
[V][component:204]: Component wifi took a long time for an operation (0.07 s).
[I][ota:113]: Boot seems successful, resetting boot loop counter.
[D][esp32.preferences:114]: Saving 1 preferences to flash...
[V][esp32.preferences:126]: sync: key: 233825507, len: 4
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[D][switch:016]: 'Hoftor auf' Turning OFF.
[D][switch:016]: 'Hoftor ein' Turning OFF.
esphome:
friendly_name: Hoftor
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: verbose
# Enable Home Assistant API
api:
encryption:
key: !secret api_password
ota:
password: !secret esp32-hoftor_password
wifi:
ssid: !secret wifi_ssid
manual_ip:
# To set a static IP for the ESP
static_ip: 192.168.188.103
gateway: 192.168.188.1
subnet: 255.255.255.0
ap:
ssid: fba-hoftor_ssid
password: fba-hoftor_password
captive_portal:
# Definitionen der Schalter für den Optokoppler
switch:
# Tor an, Betrieb
- platform: gpio
pin:
number: 33 # Schaltet das Hoftor ein: Kanal 6
inverted: false
mode:
output: true
restore_mode: always off
#Polwendung Auf oder Zu
- platform: gpio
pin:
number: 32 # Polwenderelais ein: Auf, aus: Zu: Kanal 7
inverted: false
mode:
output: true
#Torgeschwindigkeit
- platform: gpio
pin:
number: 22 # 24V / 12V Umschaltung: Kanal 8
inverted: false
mode:
output: true
# Warnleuchte
- platform: gpio
pin:
number: 13 # Schaltet die Warnleuchte ein: Kanal 5
inverted: false
mode:
output: true
binary_sensor:
# Bewegungsrichtung ermitteln aus Schalterzuständen
lambda: |-
if ((id(ht_on).state = "on") && (id(ht_auf).state = "on")) {
// Tor öffnet.
return true;
} else {
// Tor bewegt sich nicht.
return false;
name: "Tor schliesst"
lambda: |-
if ((id(ht_on).state = "on") && (id(ht_auf).state = "off")) {
// Tor schliesst.
return true;
} else {
return false;
# Lichtschranke
- platform: gpio
pin:
number: 27 # Lichtschranke schaltet bei Unterbrechung aus
mode:
input: true
pullup: true
inverted: false
# Endschalter
- platform: gpio
pin:
number: 25 # Endschalter ganz zu
mode: INPUT_PULLUP
inverted: false
- platform: gpio
pin:
number: 26 # Endschalter ganz offen
mode: INPUT_PULLUP
inverted: false
# Art der Hoftorsteuerung
cover:
- platform: feedback
device_class: gate
assumed_state: true
has_built_in_endstop: false
max_duration: 60s
open_duration: 55s
direction_change_wait_time: 500ms
# open_sensor: tor_oeffnet
open_endstop: hoftor_offen
open_obstacle_sensor: lichtschranke
close_duration: 30s
# close_sensor: tor_schliesst
close_endstop: hoftor_zu
close_obstacle_sensor: lichtschranke
obstacle_rollback: 5%
open_action:
- switch.turn_on: warnleuchte
- delay: 2s
- switch.turn_on: ht_auf
- switch.turn_off: ht_speed
- switch.turn_on: ht_on
close_action:
- delay: 2s
- switch.turn_off: ht_auf # ausgeschaltet schließt das Tor
stop_action:
- switch.turn_off: ht_on
- delay: 1s
- switch.turn_off: warnleuchte
log recorded wirelessly installed in place
INFO ESPHome 2023.5.5
INFO Reading configuration /config/esphome/Hoftor.yaml...
INFO Starting log output from 192.168.188.103 using esphome API
INFO Successfully connected to 192.168.188.103
[00:51:53][I][app:102]: ESPHome version 2023.5.5 compiled on Jun 15 2023, 18:04:10
[00:51:53][C][wifi:505]: WiFi:
[00:51:53][C][wifi:363]: Local MAC: C8:F0:9E:F4:52:04
[00:51:53][C][wifi:364]: SSID: [redacted]
[00:51:53][C][wifi:365]: IP Address: 192.168.188.103
[00:51:53][C][wifi:367]: BSSID: [redacted]
[00:51:53][C][wifi:368]: Hostname: 'hoftor'
[00:51:53][C][wifi:370]: Signal strength: -74 dB ▂▄▆█
[00:51:53][V][wifi:372]: Priority: -3.0
[00:51:53][C][wifi:374]: Channel: 6
[00:51:53][C][wifi:375]: Subnet: 255.255.255.0
[00:51:53][C][wifi:376]: Gateway: 192.168.188.1
[00:51:53][C][wifi:377]: DNS1: 0.0.0.0
[00:51:53][C][wifi:378]: DNS2: 0.0.0.0
[00:51:53][C][logger:301]: Logger:
[00:51:53][C][logger:302]: Level: VERBOSE
[00:51:53][C][logger:303]: Log Baud Rate: 115200
[00:51:53][C][logger:305]: Hardware UART: UART0
[00:51:53][C][switch.gpio:068]: GPIO Switch 'Hoftor ein'
[00:51:53][C][switch.gpio:091]: Restore Mode: always OFF
[00:51:53][C][switch.gpio:031]: Pin: GPIO33
[00:51:53][C][switch.gpio:068]: GPIO Switch 'Hoftor auf'
[00:51:53][C][switch.gpio:031]: Pin: GPIO32
[00:51:53][C][switch.gpio:068]: GPIO Switch 'Hoftor speed'
[00:51:53][C][switch.gpio:031]: Pin: GPIO22
[00:51:53][C][switch.gpio:068]: GPIO Switch 'Warnleuchte'
[00:51:53][C][switch.gpio:031]: Pin: GPIO13
[00:51:53][C][template.binary_sensor:018]: Template Binary Sensor 'Tor oeffnet'
[00:51:54][C][template.binary_sensor:018]: Template Binary Sensor 'Tor schliesst'
[00:51:54][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Lichtschranke'
[00:51:54][C][gpio.binary_sensor:016]: Pin: GPIO27
[00:51:54][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Endschalter_S'
[00:51:54][C][gpio.binary_sensor:016]: Pin: GPIO25
[00:51:54][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Endschalter_N'
[00:51:54][C][gpio.binary_sensor:016]: Pin: GPIO26
[00:51:54][C][feedback.cover:052]: Endstop Cover 'Hoftor'
[00:51:54][C][feedback.cover:052]: Assumed State: YES
[00:51:54][C][feedback.cover:052]: Device Class: 'gate'
[00:51:54][C][feedback.cover:053]: Open Duration: 55.0s
[00:51:54][C][feedback.cover:055]: Open Endstop 'Endschalter_N'
[00:51:54][C][feedback.cover:057]: Open Obstacle 'Lichtschranke'
[00:51:54][C][feedback.cover:059]: Close Duration: 30.0s
[00:51:54][C][feedback.cover:061]: Close Endstop 'Endschalter_S'
[00:51:54][C][feedback.cover:063]: Close Obstacle 'Lichtschranke'
[00:51:54][C][feedback.cover:072]: Max Duration: 60.0s
[00:51:54][C][feedback.cover:075]: Direction change wait time: 0.5s
[00:51:54][C][feedback.cover:082]: Obstacle rollback: 5.0%
[00:51:54][C][captive_portal:088]: Captive Portal:
[00:51:54][C][mdns:108]: mDNS:
[00:51:54][C][mdns:109]: Hostname: hoftor
[00:51:54][V][mdns:110]: Services:
[00:51:54][V][mdns:112]: - _esphomelib, _tcp, 6053
[00:51:54][V][mdns:114]: TXT: friendly_name = Hoftor
[00:51:54][V][mdns:114]: TXT: version = 2023.5.5
[00:51:54][V][mdns:114]: TXT: mac = c8f09ef45204
[00:51:54][V][mdns:114]: TXT: platform = ESP32
[00:51:54][V][mdns:114]: TXT: board = esp32dev
[00:51:54][V][mdns:114]: TXT: network = wifi
[00:51:54][C][ota:093]: Over-The-Air Updates:
[00:51:54][C][ota:094]: Address: 192.168.188.103:3232
[00:51:54][C][ota:097]: Using Password.
[00:51:54][C][api:138]: API Server:
[00:51:54][C][api:139]: Address: 192.168.188.103:6053
[00:51:54][C][api:141]: Using noise encryption: YES
[00:52:17][D][cover:076]: 'Hoftor' - Setting
[00:52:17][D][cover:080]: Command: STOP
[00:52:17][D][cover:170]: 'Hoftor' - Publishing:
[00:52:17][D][cover:173]: Position: 100%
[00:52:17][D][cover:186]: Current Operation: IDLE
[00:52:17][D][feedback.cover:385]: 'Hoftor' - Firing 'STOP' trigger.
[00:52:17][D][switch:016]: 'Hoftor ein' Turning OFF.
[00:52:17][D][switch:016]: 'Hoftor auf' Turning OFF.
[00:52:17][D][switch:016]: 'Hoftor speed' Turning OFF.
[00:52:18][D][switch:016]: 'Warnleuchte' Turning OFF.
[00:52:23][D][switch:016]: 'Hoftor auf' Turning OFF.
[00:52:25][D][switch:016]: 'Hoftor ein' Turning OFF.
[00:52:26][D][switch:012]: 'Hoftor speed' Turning ON.
[00:52:26][D][switch:055]: 'Hoftor speed': Sending state ON
[00:52:28][D][switch:012]: 'Warnleuchte' Turning ON.
[00:52:28][D][switch:055]: 'Warnleuchte': Sending state ON
[00:52:30][D][switch:016]: 'Warnleuchte' Turning OFF.
[00:52:30][D][switch:055]: 'Warnleuchte': Sending state OFF
[00:52:32][D][switch:016]: 'Hoftor speed' Turning OFF.
[00:52:32][D][switch:055]: 'Hoftor speed': Sending state OFF
[00:52:33][D][switch:016]: 'Hoftor ein' Turning OFF.
[00:52:35][D][switch:016]: 'Hoftor auf' Turning OFF.
[00:52:57][D][esp32.preferences:114]: Saving 1 preferences to flash...
[00:52:57][V][esp32.preferences:137]: NVS data not changed skipping 2617425443 len=8
[00:52:58][D][esp32.preferences:143]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
The differences between the different switches are some sending feedback “Sending state …”, but the two switches ‘Hoftor auf’ and ‘Hoftor ein’ they do not send a feedback.
By the way the two template binary sensors “Tor schliesst” and “Tor oeffnet” are not giving the expected result. I think the lambda is correct. May be this has also to do with the same issue.
