I have some Meross and Tuya switches installed via their respective integrations but in the entities list they are showing as both switch and device_tracker
switch
device_tracker
Is that correct? If not how can I remove them as they are not editable in the entities UI.
Yes, this is normal when you have the device-tracker abled, as they ARE devices on your network.
You can exclude devices from your device tracker, by editing the device-tracker configuration of the individual device.
Thank you.
