I have the following code in my switches.yaml:
- platform: rfxtrx
signal_repetitions: 2
devices:
"0710000045020000":
"0710000045030000":
"0710050045050000":
"0710050045030000":
The issue is that device with id 0710000045030000
seems to be in conflict with the device with id 0710050045030000
. In fact the latter device is even ignored and not registered as such in home assistant.
Both switches have the same home/unit code (E3 = 4503
), but correspond to different wall switches of different brands (0004
vs 5004
) it looks like only this part of the id is used as primary key.
The above results in:
When I change the home/unit code (e.g. to ‘4504’) the switch is registered correctly.
Simple question: is this recognized as intended behavior?
Thanks, Dennis
Btw: running hassbian with HA v0.98.5 on a RPI3.
