Hallo fellows,
I wrote my own python script switching my 433MHz sockets from Intertechno using the cheap 433MHz transmitter. In the Putty-Terminal it works great using the following shell commands:
#on
python /usr/share/hassio/homeassistant/scripts/send_Int.py a_on
#off
python /usr/share/hassio/homeassistant/scripts/send_Int.py a_off
Now I want to integrate the script as an device via shell command. I know its also possible using the Python-Script-Documentation of Hass but I also want to integrate my IR-remotes using LIRC-send via shell Command with irsend later on.
Could you tell me my programmer mistakes please? Or could you give me a hint in case I follow a wrong approach?
My configuration.yaml looks like:
shell_command:
a_on: 'ssh [email protected] python /usr/share/hassio/homeassistant/scripts/send_Int.py a_on'
a_off: ssh [email protected] python /usr/share/hassio/homeassistant/scripts/send_Int.py a_off
#set_JVC: irsend SEND_ONCE av KEY_VOLUMEUP
@PaFcio summarized the SSH shell commands here
There is a discussion of setting the permissions here. The script has the execution rights for Linux root user. Do I really need the ssh [email protected] prefix?
Also I’m not sure about the quotation marks in the shell_command. Do I need to enclose everything with --> ’ <–?
- First try using a switch: the dashboard switch in the Lovelace looks like (doesn’t work):
show_icon: true
show_name: true
tap_action:
service: shell_command.a_on
type: button
show_state: false
- Second try - using a automation
I also tried to setup an automation in automation.yaml hoping the automation works (it isn’t). It is not even listed in the automations.
- id: '1234' #random
platform: homeassistant
alias: 433MHZ-Dimmer
description: Dimmer an
event: start
- id: '1235' #random
description: Dimmer aus
event: start
service: shell_command.a_off
My System
version | core-2021.3.4 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.7 |
os_name | Linux |
os_version | 5.10.17-v7+ |
arch | armv7l |
timezone | UTC |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Hass.io
host_os | Raspbian GNU/Linux 10 (buster) |
update_channel | stable |
supervisor_version | supervisor-2021.03.6 |
docker_version | 20.10.5 |
disk_total | 58.2 GB |
disk_used | 8.1 GB |
healthy | true |
supported | failed to load: Unsupported |
supervisor_api | ok |
version_api | ok |
installed_addons | File editor (5.2.0), Spotify Connect (0.8.2), Let’s Encrypt (4.11.0), NGINX Home Assistant SSL proxy (3.0.1), Mosquitto broker (5.1.1), Zigbee2mqtt (1.18.2-1), Hey Ada! (1.1.1), Terminal & SSH (9.1.0), AirCast (3.0.0), Portainer (1.4.0) |
Lovelace
dashboards | 1 |
resources | 0 |
views | 1 |
mode | storage |
