Since I dont know the state, I cant just toggle it, I would need to check if its off, if so then toggle at 6:50am, other wise do nothing, and at 5:10pm the same, if its off, do nothing, if on, toggle.
I would like the heating to have temp condition boost from
mo 5-8
tu-fr 6-8
temp condition home
mo-th 8-16
fr 8-12
rest should be temp condition away
and only if the temp at evaluation is below the current set for home temp from the generic thermostat
If ac is on, then heat should be off (not just away) and vice versa.
For AC temp home time is mo-th 10-17 and fr 10-14
outside is away
AC only activated when temp at “forcast” sensor (I use one for cover control) is above 24°C
AC does not need to be a generic thermostat, a simple swicht is enough, the AC needs to be started manually anyway after each power resume. but I dont want the ac to run and then the heater to kick in, or run half the night and such things.
