*** THIS GUIDE IS CURRENTLY UNDER CONSTRUCTION ***
This guide is for switching from OpenZwave (Beta) to ZwaveJS2MQTT & Zwave JS Integration.
Click here for the docker image install
Preparation
In home assistant.
Browse to Developer Tools.
Click on the template tab
Paste the following code into the template section.
{%- for node, zstates in states | selectattr('attributes.node_id', 'in', range(1000)) | groupby('attributes.node_id') %} {{ node }}: {%- for s in zstates %} - {{ s.name }} {{ s.entity_id }} {% endfor %} {%- endfor %}
Copy the results and paste them to a text file for safe keeping. You’ll reference this at a later time.
Migration
Install ZwaveJS2MQTT addon.
Copy device and network_key from OpenZwave configuration.
device - This is the path for the USB Stick
network_key - This is the key used when adding a secure node. -
Stop OpenZwave (beta) addon, turn off Start on Boot and Watchdog.
Delete OpenZwave Integration.
Start ZwaveJS2MQTT addon.
Open the Web UI
Paste information into ZwaveJS2MQTT configuration area.
Watch the device list and wait for the last node to be found.
Fix all ‘unknown’ devices by waking them up. No need for a refresh node, just wake them up.
NOTE: This will require you to wake the devices up phsycially. Meaning you have to go to the device and wake it yourself. Most zwave devices have a periodic wakeup period where they wake up once a day. If you don’t want to walk around the house and wake devices, you can simply wait for the device to wake itself. Just be warned, it may take a day or 2 for this to happen.
Install Zwave JS integration. You should have a list of devices that matches devices in the ZwaveJS2MQTT control panel.
Rename Devices using the text file as a reference from the Preparation #4 step. This is the most time consuming step
