Switching from Zwave 1.4 (Deprecated) to ZWave JS UI (formerly ZwaveJS2MQTT)
thanks
but how to delete or remove it?
does it interfere the zwavejz2mqtt?
Remove the integration for ZwaveJS. Then remove the addon for ZwaveJS. Restart.
You do not need to remove ZwaveJS2MQTT addon.
OK after 2 days most of the nodes started to show up but now i am left with so many entities in the areas on Overview.
Is there a chance to remove it? I do not se where
From the entities list, remove all the unavailable ones. There should be a bulk way to do it. Configuration → entities. Then sort by unavailable.
Unfortunately i can not remove them
when i see areas lis tit shows that there are entities there
But when i enter the Area it shows no entities
Unless, I’m misunderstanding something, the information on migrating the network key appears out of date as of 0.27.0 - there are now 4 keys:
  • S2 Unauthenticated
  • S2 Authenticated
  • S2 Access Control
  • S0 Legacy
The docs say to enter both S0 and S2 keys even if not using S2, but doesn’t give any guidance on migrating the network key.
** NOTE: ** If I paste my key in both S0 Legacy and any of the other S2 key fields, there is a driver warning that shows up in the UI which looks somewhat innocuous, but it will NEVER connect to the USB device.
Instead of connecting/starting up, the log just shows:
WARN ZWAVE: Retry connection in 3 seconds...
Now that I’ve got only the S0 legacy key defined, everything finally starts up. However, I’m getting a warning from interviewing my Zwave locks:
Driver: Node 026 supports Security S2, but no S2 network keys were configured. The interview might not include all functionality.
The old “network key” is the S0 Legacy key.
Thanks for confirming that. I had pretty much figured that out. The surprise was that adding the same key to the other fields would prevent Zwave2MQTT from connecting to the USB stick without much warning.
@petro - Thanks for the helpful guide. It might be worth updating the guide to mention the S0 Legacy Key as the correct place to copy over the network key.
This has probably been discussed elsewhere, but I’m having trouble finding it.
What are the advantages of renaming devices in Home Assistant instead in the Zwave2MQTT UI?
It looks like the advantages of renaming the device in Zwave2MQTT are:
  • The names will be available in the Zwave2MQTT dashboard and network graph view. The ambiguity if you have a lot of the same devices will be removed.
  • If one does use the MQTT interface for some reason, the devices will be correctly named.
I encountered the same issue
the old key is S0 legacy
the other 3 I just generated with the generate button
worked fine for me
Thanks for the useful thread! it really helpted me, tnx
Does anybody know you you can use multiple entities for the zwave_js.refresh_value service.
I need to poll for data every 30 minutes but was thinking I could stop that and just do an automation instead.
The idea is to be able to align the collection at 30 minutes and 0 minutes on the hour rather than polling which I think is just 30 minutes from when the changes were saved so it could be polling at 15 minutes and 45 minutes in the hour.
If I can do this my automation action list is going to be huge but if I can bulk list my entities it would be cleaner.
Thanks again
check out the docs, they explicitly say zwave_js.refresh_value excepts a list of entity_id’s.
Thanks Petro.
Just a follow up question around the syntax
For this example
service: zwave_js.refresh_value
entity_id: sensor.kitchen_powernode_fridge_energy
Do I put a , and then the next entity after the fridge_energy
or do I list the entity IDs one after the other
entity_id: sensor.kitchen_powernode_dishwasher_energy
or change entity_id for entities?
It’s no different than any other entity_id field. Have you used other services with multiple entities?
I don’t think so… Or if I have maybe it’s been a group so I haven’t called them out individually.
Happy to play around just if you had an answer on how the list would be that would be great.
Thanks again for the fast replies.
Have you defined a group in yaml before?
Basically, yaml is identical everywhere. Defining listed items does not change from one field to another. It’s all the same. I’m trying to see how much yaml you know.
  entity_id:
    - sensor.kitchen_powernode_fridge_energy
    - sensor.kitchen_powernode_dishwasher_energy
or you could separate them with a comma as well
  entity_id: sensor.kitchen_powernode_fridge_energy, sensor.kitchen_powernode_dishwasher_energy
But I find the "-’ list easier to read tho.
Hi Petro,
yes I have and you also helped me with creating groups based on key words in the entity name.
Are you suggesting I can use that same technique and create another group of zwave energy entities and call the service against that group?
