I have the following automation code which turns the boiler on or off depending on the status of 3 Generic Thermostats, depending on whether heat is required or not. Which works fine. (via a Shellyplus1 switch)
My question is, how should I change the automation if I want to replace one of the generic thermostats with a TRV (Sonoff) valve with a dial on it to set the desired temperature directly on the radiator (so not on the home assistant GUI).
The TRV entity ID is climate.0x0cae5ffffeb13446
Thank you very much!
Automation.yaml
- id: '1626606255114'
alias: Heating switch
- platform: state
entity_id: input_boolean.nappali_futes
- platform: state
entity_id: input_boolean.haloszoba_futes
- platform: state
entity_id: input_boolean.kristof_futes
- service: 'switch.turn_{{ trigger.to_state.state }}'
entity_id: switch.shellyplus1_d4d4daf3a53c_switch_0
Configuration.yaml
'input_boolean:
nappali_futes:
initial: off
haloszoba_futes:
initial: off
kristof_futes:
initial: off
climate:
- platform: generic_thermostat
name: Nappali termosztát
heater: input_boolean.nappali_futes
target_sensor: sensor.a4_c1_38_ec_d0_56_d056_temperature
min_temp: 15
max_temp: 30
ac_mode: false
target_temp: 22
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_hvac_mode: "off"
away_temp: 16
precision: 0.1'
