I am finally leaving Wink…. I have moved my locks and water sensors/valve control. But I want to connect my Go Control sensor (Door and Motion) and want to set up some automations… ie. if a door is opened turn on light or if there is motion (or no motion) that lights can be turned on or off. I am using the IOS version of Home Assistant and not very savvy with programming but willing to try things. Any Help would be appreciated.
Below is an automation I use to turn on and off closet and room lighting from a single automation.
Trigger - If sensor goes from closed to open OR open to closed
Action
Choose: if open then on
Else: if closed then off
alias: Pantry - Turn on-off Light when door is open-closed
description: 'Control Light based on Door condition'
- platform: state
entity_id: binary_sensor.pantry_door_sensor <--The sensor Remove this
to: 'on'
- platform: state
to: 'off'
condition: []
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- service: switch.turn_on
entity_id: switch.pantry_light <-- The switch --remove this
- conditions:
- condition: state
state: 'off'
sequence:
- service: switch.turn_off
default: []
mode: single
You can create this in Configuration–> Automations using the gui. You can also change to yaml mode and cut and paste. The ← starts a comment and should be removed.
