Dear all,
my current configuration is the following and I’m using HACS 1.22.0
System Health
Title Value version core-2022.2.9 installation_type Home Assistant OS dev false hassio true docker true user root virtualenv false python_version 3.9.7 os_name Linux os_version 5.10.92-v8 arch aarch64 Home Assistant Community Store
Title Value GitHub API ok Github API Calls Remaining 4969 Installed Version 1.22.0 Stage running Available Repositories 1073 Downloaded Repositories 12 Home Assistant Cloud
Title Value logged_in false can_reach_cert_server ok can_reach_cloud_auth ok can_reach_cloud ok Home Assistant Supervisor
Title Value host_os Home Assistant OS 7.4 update_channel stable supervisor_version supervisor-2022.01.1 docker_version 20.10.9 disk_total 28.6 GB disk_used 8.9 GB healthy true supported true board rpi4-64 supervisor_api ok version_api ok installed_addons Mosquitto broker (6.0.1), Zigbee2mqtt (1.24.0-1), Terminal & SSH (9.3.0), Samba share (9.5.1), Node-RED (11.0.4), ESPHome (2022.2.5) Lovelace
Title Value dashboards 1 resources 5 views 9 mode storage
I always get the following error message, if I installed a theme form HACS (e.g. Noctis).
Logger: homeassistant.core
Source: components/frontend/init.py:468
First occurred: 14:41:04 (2 occurrences)
Last logged: 20:41:49
- Error executing service: <ServiceCall frontend.reload_themes (c:b371c8e5fb3b7e1b055aacaa9362cd7b)>
- Error executing service: <ServiceCall frontend.reload_themes (c:46be1fb1f056235d9f60cabe290a576e)>
File “/usr/src/homeassistant/homeassistant/core.py”, line 1648, in catch_exceptions
await coro_or_task
File “/usr/src/homeassistant/homeassistant/core.py”, line 1667, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 738, in admin_handler
await result
File “/usr/src/homeassistant/homeassistant/components/frontend/init.py”, line 468, in reload_themes
new_themes = config[DOMAIN].get(CONF_THEMES, {})
KeyError: ‘frontend’
If I switch to the intergrated dark theme via my profil configuration it works and the dark theme is used. Also after searching on the Internet I could not find a solution. Do you have an idea?
