Are you talking about this ID?
Do not use integra identifier in configuration.yaml use one of your users keypad code. For me it was the problem.
ahhhh⦠I see. OK⦠I will try that. Thanks a lot for the info. I would be amazed if all of this time that was the blocking point. I will post back here if I get it working. Thanks a lot XSA!
Brian
Arm/Disarm worked even with that code but output triggering not.
For me as well. Thatās why I thought the integration was working properly and just my set up was not good for triggering the switchable outputs. Thanks again!
Use the port where the garage door opener is phiscally connected to. According to previous post of yours it is 17 and 18. There is nothing to do with triggering zones.
It worked!!! I canāt believe that it was that simple. I spent hours trying to debug this last year. And following your tip, it was solved in 5 minutes (1 minute to update the code⦠4 minutes to restart the HA core).
I owe you a beer XSA! Actually, a six-pack!
Thanks again for posting your findings here.
Brian
Can you help me out? I have my siren on output 1 and would like to know how to turn the siren on or off using Home Assistant.
Thanks!
I figured it out. User pincode to arm/disarm does not work for switchable outputs. You have to use the guardx code.
Hello, my name is Nicola, I am approaching for the first time to home assistant, I have installed on rasberry, I can configure everything (sockets controlled etc) now I bought a central integra64 with eth1 plus, I would like to control from ha, but I have some doubts.
in HA i created my own dash board, but i can not create a dedicated card for the alarm.
i have a default Alarm Panel Card Configuration but it is in error.
someone can give me a guide
thank you very much
Is it possible to create a virtual zone and connect it to a virtual output. I want to be able to trigger the alarm system from within home assistant.
I have fibaro smoke sensors connected to home assistant and I would like to trigger fire alarm when the fibaro smoke detectors detect smoke.
Zone type 8: follow output does not work
UPDATE: I have it working now. I created a virtual output using a 25: BI switch
I created a zone using type 8 followeing the virtual output and set 33: 24h smoke
Now I have a switch in Home Assistant and a binary sensor. Flipping the switch flips the zone and boom. Fire alarm is triggered!
You have to select the Entity. I have a device alarm.panel. available when adding the alarm to the configuration.yaml.
This is basic Home Assistant stuff. Make other things work first and you will understand the rest of this problem.
Hi herwarth, the problem is that I canāt see the SATEL entity, i configured this,
I was able to configure spotify, much more complex
where am I wrong,
give me a hand thanks a lot
Perhaps the problem is in your satel configuration. Did you manage to configure your satel network card with dloadx? Make a screenshot
Hi Herwarth, I thank you in advance for your help, but I canāt get over it I am attaching you screnshot
Hi @nicproteo,
I am just looking at this topic, because I am planning to upgrade my old Satel, but looking at your picture, I think, you have to turn off Integrazione criptata, next to the port. According the documentation, encrypted mode is not supported.
@krash, could you confirm that is the option for encrypted communication? I am not familiar with the software and just being a spectator at the moment.
Edit: And I think you need to add a partition as well to your configuration.yaml.
@nicproteo, I think that you still have a formatting problem in the configuration.yaml
Look at the full example on this page, especially the formatting of the partitions and zones (number of spaces)
I did itā¦
hyppe
Hi Guys,
Unfortunately, I have to ask you for help, despite several hours of reading and many attempts - I couldnāt make it.Im totally noob of HA with a bit experience in Domoticz.
Below my configuration.yaml
Pastebin: satel_integra - Pastebin.com
I have problem with switchable_outputs. I can arm alarm, i see that my motion detectors changing status (detect my moves) but ufnortunately i cant manage with switchable outputs. I think everything is ok with my setup on integra because those switches were working properly on domoticz.
When i turn on switch from Integra App - i see that in HA but i cant do that via HA, nothing happened.
I enter code with 4 numbers which i use for arm/disarm so it must be ok.
Please help me, i dont want go back to Domoticz
Thanks in advance for any help,
Bartek
