When the google calendar was added a bit ago. I futzed around with the calendar and got it working with my normal gmail account. It was working fine for a bit then it stopped working but I had no triggers set up for it so I sort of ignored it and commented out the google section.
Recently I wanted to do the integration again but this time set it up with my G Suite calendar. So I went through the process again, delete the orignal app from gmail and created a new one under my G Suite account. Added the new client id/secret to my secret.yaml file, reenabled google in my configuration.yaml. I also changed the cal_id in google_calendars.yaml to point to my G Suite account. But I cannot get the HA UI to prompt me for the activation.
Running: 0.84.6 (docker) Is there anything else I need to delete or switch?
configuration.yaml:
google:
client_id: !secret gcal_clientid
client_secret: !secret gcal_secret
track_new_calendar: true
google-calendars.yaml:
- cal_id: [email protected]
entities:
- device_id: aram
ignore_availability: true
track: true
here is the relevant log entries:
2018-12-24 11:25:41 ERROR (MainThread) [homeassistant.helpers.entity] Update for calendar.aram_mirzadeh fails
File "/usr/src/app/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/usr/src/app/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/calendar/__init__.py", line 155, in update
if not self.data or not self.data.update():
File "/usr/src/app/homeassistant/util/__init__.py", line 324, in wrapper
result = method(*args, **kwargs)
File "/usr/src/app/homeassistant/components/calendar/google.py", line 113, in update
result = events.list(**params).execute()
File "/usr/local/lib/python3.6/site-packages/oauth2client/_helpers.py", line 133, in positional_wrapper
return wrapped(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/googleapiclient/http.py", line 837, in execute
method=str(self.method), body=self.body, headers=self.headers)
File "/usr/local/lib/python3.6/site-packages/googleapiclient/http.py", line 163, in _retry_request
resp, content = http.request(uri, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/oauth2client/transport.py", line 186, in new_request
credentials._refresh(orig_request_method)
File "/usr/local/lib/python3.6/site-packages/oauth2client/client.py", line 756, in _refresh
self._do_refresh_request(http)
File "/usr/local/lib/python3.6/site-packages/oauth2client/client.py", line 812, in _do_refresh_request
raise HttpAccessTokenRefreshError(error_msg, status=resp.status)
oauth2client.client.HttpAccessTokenRefreshError: deleted_client: The OAuth client was deleted.
