How to put this “SY1-ZigBee Smart Metering Switch (qeuvnohg) by Tuya” to manage the total power consumption in the home assistant?
In the home assistant it only has the on and off function.
If you open the device info, does it show any sensors?
Did you try the suggestion posted her: [Support new devices | Zigbee2MQTT]
No, just on and off function
As of 2024-03 this kind of devices show the power, current and voltage information, although they might be disabled:
My only issue is the data seems to be static, and only when I check the device in the Smart Life app, updated values are pushed to Home Assistant.
Adding the diagnostics data:
"home_assistant": {
"installation_type": "Home Assistant Container",
"version": "2024.3.0",
"dev": false,
"hassio": false,
"virtualenv": false,
"python_version": "3.12.2",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Madrid",
"os_name": "Linux",
"os_version": "6.5.0-25-generic",
"run_as_root": true
"custom_components": {
"wundergroundpws": {
"version": "2.0.6",
"requirements": []
"hacs": {
"version": "1.34.0",
"requirements": [
"aiogithubapi>=22.10.1"
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"codeowners": [
"@Tuya",
"@zlinoliver",
"@frenck"
"config_flow": true,
"dependencies": [
"ffmpeg"
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-device-sharing-sdk==0.1.9"
"is_built_in": true
"data": {
"endpoint": "https://apigw.tuyaeu.com",
"terminal_id": "17079086049214wGiQJ",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"id": "bfab24edc0846aea91zvia",
"name": "Interruptor general",
"category": "dlq",
"product_id": "qeuvnohg",
"product_name": "SY1-ZigBee Smart Metering Switch",
"online": true,
"sub": true,
"time_zone": "+02:00",
"active_time": "2024-03-14T09:58:52+00:00",
"create_time": "2024-03-14T09:58:52+00:00",
"update_time": "2024-03-14T09:58:52+00:00",
"function": {
"switch": {
"type": "Boolean",
"value": {}
"countdown_1": {
"type": "Integer",
"value": {
"unit": "s",
"min": 0,
"max": 43200,
"scale": 0,
"step": 1
"relay_status": {
"type": "Enum",
"value": {
"range": [
"power_off",
"power_on",
"last"
"light_mode": {
"type": "Enum",
"value": {
"range": [
"none",
"relay",
"pos",
"on"
"child_lock": {
"type": "Boolean",
"value": {}
"online_state": {
"type": "Enum",
"value": {
"range": [
"online",
"offline"
"status_range": {
"switch": {
"type": "Boolean",
"value": {}
"countdown_1": {
"type": "Integer",
"value": {
"unit": "s",
"min": 0,
"max": 43200,
"scale": 0,
"step": 1
"add_ele": {
"type": "Integer",
"value": {
"unit": "kW\u00b7h",
"min": 0,
"max": 9999999,
"scale": 3,
"step": 100
"cur_current": {
"type": "Integer",
"value": {
"unit": "mA",
"min": 0,
"max": 99999,
"scale": 0,
"step": 1
"cur_power": {
"type": "Integer",
"value": {
"unit": "W",
"min": 0,
"max": 260000,
"scale": 1,
"step": 1
"cur_voltage": {
"type": "Integer",
"value": {
"unit": "V",
"min": 0,
"max": 9999,
"scale": 1,
"step": 1
"test_bit": {
"type": "Integer",
"value": {
"min": 0,
"max": 5,
"scale": 0,
"step": 1
"voltage_coe": {
"type": "Integer",
"value": {
"min": 0,
"max": 999999,
"scale": 0,
"step": 1
"electric_coe": {
"type": "Integer",
"value": {
"min": 0,
"max": 999999,
"scale": 0,
"step": 1
"power_coe": {
"type": "Integer",
"value": {
"min": 0,
"max": 999999,
"scale": 0,
"step": 1
"electricity_coe": {
"type": "Integer",
"value": {
"min": 0,
"max": 999999,
"scale": 0,
"step": 1
"fault": {
"type": "Bitmap",
"value": {
"label": [
"ov_cr",
"ov_vol",
"ov_pwr",
"ls_cr",
"ls_vol",
"ls_pow",
"short_circuit_alarm",
"overload_alarm",
"leakagecurr_alarm",
"self_test_alarm",
"high_temp",
"unbalance_alarm",
"miss_phase_alarm"
"relay_status": {
"type": "Enum",
"value": {
"range": [
"power_off",
"power_on",
"last"
"light_mode": {
"type": "Enum",
"value": {
"range": [
"none",
"relay",
"pos",
"on"
"child_lock": {
"type": "Boolean",
"value": {}
"status": {
"switch": true,
"countdown_1": 0,
"add_ele": 9330,
"cur_current": 2447,
"cur_power": 3690,
"cur_voltage": 2290,
"test_bit": 0,
"voltage_coe": 0,
"electric_coe": 0,
"power_coe": 0,
"electricity_coe": 0,
"fault": 0,
"relay_status": "last",
"light_mode": "relay",
"child_lock": false
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": [
"disabled": true,
"disabled_by": "integration",
"entity_category": null,
"device_class": null,
"original_device_class": "current",
"icon": null,
"original_icon": null,
"unit_of_measurement": "A",
"state": null
"disabled": true,
"original_device_class": "voltage",
"icon": null,
"unit_of_measurement": "V",
"state": null
"disabled": false,
"entity_category": "config",
"original_device_class": null,
"icon": null,
"original_icon": "mdi:account-lock",
"unit_of_measurement": null,
"state": {
"entity_id": "switch.interruptor_general_bloqueo_infantil",
"state": "off",
"attributes": {
"icon": "mdi:account-lock",
"friendly_name": "Interruptor general Bloqueo infantil"
"last_changed": "2024-03-14T10:12:04.474904+00:00",
"last_updated": "2024-03-14T10:12:04.474904+00:00"
"disabled": false,
"icon": null,
"state": {
"entity_id": "switch.interruptor_general_interruptor",
"state": "on",
"attributes": {
"friendly_name": "Interruptor general Interruptor"
"last_changed": "2024-03-14T10:12:04.475119+00:00",
"last_updated": "2024-03-14T10:12:04.475119+00:00"
"disabled": false,
"original_device_class": "power",
"icon": null,
"unit_of_measurement": "W",
"state": {
"entity_id": "sensor.interruptor_general_potencia",
"state": "369.0",
"attributes": {
"state_class": "measurement",
"device_class": "power",
"friendly_name": "Interruptor general Potencia"
"last_changed": "2024-03-15T09:09:58.862533+00:00",
"last_updated": "2024-03-15T09:09:58.862533+00:00"
"disabled": false,
"original_device_class": "energy",
"icon": null,
"original_icon": "mdi:chart-histogram",
"state": {
"entity_id": "sensor.consumo_santo_angel",
"state": "8.76",
"attributes": {
"state_class": "total",
"source": "sensor.interruptor_general_potencia",
"unit_of_measurement": "kWh",
"device_class": "energy",
"friendly_name": "Consumo Santo Angel"
"last_changed": "2024-03-15T09:09:58.863256+00:00",
"last_updated": "2024-03-15T09:09:58.863256+00:00"
"disabled": false,
"icon": null,
"state": {
"entity_id": "sensor.consumo_diario_santo_angel",
"state": "0.01",
"attributes": {
"state_class": "total_increasing",
"source": "sensor.consumo_santo_angel",
"status": "collecting",
"last_period": "0",
"last_valid_state": "8.76",
"meter_period": "daily",
"cron pattern": "0 0 * * *",
"last_reset": "2024-03-15T09:09:30.984377+00:00",
"friendly_name": "Consumo diario Santo Angel"
"last_changed": "2024-03-15T09:09:58.864488+00:00",
"last_updated": "2024-03-15T09:09:58.864488+00:00"
"set_up": true,
"support_local": true
I’ve experimented with Tuya API and command that set “online_state” to “online” make alive this Smart Switch for about a minute or two. But I don`t know how to make it automatically in HA (for example each 60 seconds)
