Probably a long-shot, but I’m wondering if anybody has experienced something similar…
I have two VMs - one with HASSOS and the other with Node Red running in a docker container (ie. not the addon). I have the Samba Share addon running under HA, which shares “backup”, “config”, and “share”. And I have the Google Drive Backup addon doing backups every day at 6am.
I mount these three volumes on the second VM using autofs. Then I make them available to the Node Red container, for example mapping /mnt/remote/ha/backup
to /ha/backup
. I have Node Red write some stuff to “share” at 5am every day, and read “backup” every day at 8am to analyse the content of the backup files.
After a while (weeks?), the read of “backup” starts failing with “symbolic link loop” despite it containing no symlinks (although possibly the container mount or CIFS mount behaves like a symlink). At this time, if I use Portainer to connect to the Node Red container, doing ls /ha/backup
gives me the same error, but not for “config”. However ls /mnt/remote/ha/backup
works fine on the VM, so it’s only an issue with the container. If I restart the container, it’s then fine for a while again. I probably should have tried stat /ha/backup/*
to see what I get, but I’ve restarted now.
I’m tired of restarting the container. I only started monitoring the backup size because one of the addons went crazy and filled up my Google Drive, and I’m not even using that any more. Any thoughts before I just abandon the idea?
