When executing the “sync devices” command in google assistant, I get the message: “Fine, I’m syncing devices for Home Assistant. LM-G 710 is not available. You can try resetting this device”.
This device is my smartphone. When I logged in with this device via the home assistant app at the time, I left LM-G 710 that suggested the app. In the meantime I noticed that he uses this name to form the different entities. So I removed the integration in home assistant and logged in again with my name.
But apparently that LM-G 710 is still hanging somewhere.
Any idea what else I should look at?
