Hi All,
I have a custom component which I am currently trying to rewrite into async.
Within my old light entity I had the following method:
def turn_on(self, **kwargs):
"""Turn the light on."""
_LOGGER.debug("%s: turn_on: %s", self._board.friendlyname, self._name)
self._board.SetLight(self._identifier,STATE_ON)
trying to rewrite this into async following this instruction my code looks like the following:
async def async_turn_on(self, **kwargs) -> None:
"""Async: Turn the light on"""
try:
_LOGGER.debug("%s: async_turn_on: %s", self._board.friendlyname, self._name)
self.hass.async_add_executor_job(self._board.SetLight(self._identifier,STATE_ON))
except Exception as e:
_LOGGER.error("async_turn_on: Failed to turn on %s: %s", self._name, str(e))
unfortunately with this I receive the error:
2021-08-25 08:46:13 DEBUG (MainThread) [custom_components.dscriptmodule.light_class] dS-technik: async_turn_on: dS-technik_Light2
2021-08-25 08:46:13 DEBUG (MainThread) [custom_components.dscriptmodule.light_class] dS-technik: async update dS-technik_Light2
2021-08-25 08:46:13 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 52, in run
TypeError: ‘bool’ object is not callable
Due to this my current workaround is the following:
try:
await asyncio.sleep(0)
never the less I doubt this is the intended way to go async here…
Any advice how this should be translated correctly as the underlying python class holding the “_board.SetLight()” method is not async at the moment.
Thanks for your help in advance
