Synch ac with switch
this blueprint is use to link a switch (i use unwired wall switch) to air conditioner.
→ for this to work you will need a switch connected to home assiassistant and an air conditioner connceted to home assiassistant
if you have a smart ac, and smart switch, yo’ll be able to link them together, so you can turn on and off the ac using the wall smart switch.
also, the smart switch will show if the ac [HVAC] is on or off.
blueprint:
  description: synch switch with ac
  domain: automation
  source_url: https://github.com/MosheRW/homeAsistantBlueprints/blob/d85a9be8268477a8ef216d02462b2c2019d670bf/sync_ac_with_switch.yaml
  author: Moshe Winberg
  input:
    switch_entity:
      selector:
        entity:
          filter:
            device_class: switch
            domain: switch
    ac_entity:
      selector:
         entity:
          filter:
            domain: climate
mode: single
  - platform: state
    entity_id: !input switch_entity
    to: "off"
    alias: the switch turned off
  - platform: state
    to: "on"
    alias: the switch turned on
  - platform: state
    entity_id: !input ac_entity
    to: null
    alias: the ac turned on
  - platform: state
    to: "off"
condition:
  - alias: if one of the cons is true
    condition: or
    conditions:
      - alias: if the ac is on
        condition: and
        conditions:
          - condition: trigger
            id:
              - switch off
          - condition: not
            conditions:
              - condition: state
                entity_id:
                  - !input ac_entity
                state: "off"
      - alias: if the ac is off
        condition: and
        conditions:
            id:
              - switch on
          - condition: state
            state: "off"
      - alias: if the switch is on
        condition: and
        conditions:
            id:
              - ac off
          - condition: not
            conditions:
              - condition: state
                state: "on"
      - alias: if the switch is off
        condition: and
        conditions:
            id:
              - ac on
          - condition: not
            conditions:
              - condition: state
                state: "off"
  - choose:
      - conditions:
            id:
              - switch off
        sequence:
          - service: climate.set_hvac_mode
              hvac_mode: "off"
        alias: ac power off
      - conditions:
            id:
              - switch on
        sequence:
              hvac_mode: "cool"
        alias: ac power on
      - conditions:
            id:
              - ac on
        sequence:
          - service: switch.turn_on
        alias: הפעלת הכפתור
      - conditions:
            id:
              - ac off
        sequence:
          - service: switch.turn_off
            alias: switch power off
hi there, can you explain more on what is the use-case here?
I have just updated the OG. (I also fixed the documentation, and one bug)
