Syncthing Open Web UI not working
I’ve installed the Syncthing Homeassistant supervisor addon - latest version running in a VM on NAS. Syncin works and no errors in the log.
Web UI used to open (when I set it up), but now I cannot open it at all. I’ve tried the “Open Web UI” from the addon info page as well as direct Urls including http://IP:8384, http://IP:8384, http://127.0.0.1:8384, etc. Log says:
[GOLXX] 11:51:48 INFO: GUI and API listening on [::]:8384
[GOLXX] 11:51:48 INFO: Access the GUI via the following URL: https://127.0.0.1:8384/
[GOLXX] 11:51:48 INFO: My name is "Homeassistant 243ffc37-syncthing"
I’ve even tried (according to google searches) editing the Syncthing config file to change to
<address>0.0.0.0:8384</address>
Didn’t work. Could really use some help figuring this out.
Hello, you have to configure the port in the add-on configuration - if you want it to be available on 8384, then just put 8384 here:
Even without this configuration, it should be available inside Home Assistant by clicking Open Web UI or from the sidebar, if you have it there.
However, the reason I found your post is that it does not work for me reliably. It works after restarting the add-on, but subsequent tries open just blank page with the Syncthing bottom bar. Access in an individual browser tab through http://IP:8384 works fine though (when the port is configured).
Thanks for reply. My solution was to manually modify the config.xml file to disable https requirement. I wasn’t able to find another way to make it work.
